Strife025
Hi I just finished building my computer last night, everything running perfect at stock, updated drivers, and all that jazz.
So now I'm overclocking.
First I tried a 4.0ghz (191 x 21) @ 1.30v cpu core, 1.315v qpi/dram, disabling all of the recommended stuff, and manually setting my corsair dominator to 8-8-8-24 1.64v and auto everything else. I crashed on the 3rd loop of Prime95 on the Lucas-Lehmer iterations (the one that maxes power/heat).
I then lowered my clock down to 3.9ghz, everything else the same. I ran through 8 loops of same test and then 8 loops of Ram stress on Prime95, so I chalked that up to being stable.
Currently @ 3.9, I'm hitting 37-43C depending on the core at idle, and 75-82C @ 100% load after a few loops of prime. I want to know if those temps are okay and if it is okay to raise my cpu core voltage a little to hit 4.0ghz, since that is what I'm aiming for. I know some people say as high as 1.35v cpu core is fine, but are my temps okay or a bit too high?
I'm coming from an e8400 @ 4.0ghz where I never made it over low 60s, although I know the i7 is different.
System Background:
i7-930 w/ Hyper 212+ Heatsink 2 fans in Push-Pull setup and OCZ Freeze
X58A-UD3R
6 gigs Corsair Dominator
5870
in a CM HAF 932
Thanks!
System Background:
X58A-UD3R
5870
in a CM HAF 932
Thanks!
