- Jul 25, 2007
- 314
- 0
- 71
So, I'm working on a box currently based around an i7 920 D0 on an E760 Classified. I've lapped the CPU to 1200grit and it passed a flatness test. I used the dots and X method of applying the G751 thermal paste on top of the IHS and attached the Noctua UH12P SE2 (push/pull), which is currently unlapped but very flat from the factory.
Everything is in a Coolermaster Stacker 830 with 3xScythe S-Flex SFF21F on the side for intake, 2x SFF21F in the front for intake (one is ducted via custom plexi duct through the #2,#3, and #4 from the top 5 1/4 slots right into the CPU cooler over the RAM), 1x SFF21F in the top for exhaust, and 1x SFF21F in the rear for exhaust + the PSU fan. Additionally there is a 60mm fan on the NB heatsink blowing towards the top (NB is at 55-60C pretty constant) and over the heatpipes on the bottom of the CPU cooler. Room ambient temp is 67F.
I'm currently 1 hour stable Prime95, but after about 1 hour and 30 minutes, it BSODs usually with a 101 error code (indicating I need to increase CPU vCore). My issue is I have the voltage higher for stability than I'd like it to be and I'm being forced to push it further, which is causing my temps to go above my window. Peak load is 85C on Core 0, avg load is 83C. I'd like to see peak load of 80C and avg load of 75C+. I'm planning on lapping the cooler and reapplying the thermal paste tomorrow, but I'm looking for other ideas.
Any ideas would be helpful, as at this point I'm at a loss for what to do other than lapping the cooler and pressure modding it to try to drop the temps, but that's only going to gain me maybe 3C across the board. Any and all ideas welcome.
My current BIOS template follows:
Mother Board ( EVGA X58 Classified E760 )
Bios ( S61H )
CPU ( 920 D0 )
CPU Cooler ( Noctua NHU12P SE2 Push/Pull )
Memory ( Corsair Dominator GT 1866 7 8 7 20 )
PSU ( Enermax Revolution85+ 1050W April 2009 Rev2 )
GPU ( EVGA GTX275 Superclock 1.75GB X 2 )
Drivers ( 191.07 )
Operating System ( Windows 7 64bit Ultimate )
Frequency Control
CPU Clock Ratio ( 20X )
CPU Host Frequency (Mhz) ( 200 )
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( 3205hz { 16X } )
CPU Clock Skew ( 0 ps )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 101 )
Memory Feature
Memory Speed ( XMP Profile 1 )
Memory Control Setting ( Enabled )
Memory Frequency ( 1600Mhz / 2:8 )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( 7 )
tRCD Setting ( 8 )
tRP Setting ( 7 )
tRAS Setting ( 20 )
tRFC Setting ( 57 )
Command Rate ( 1t )
Voltage Control
EVGA VDroop Control ( Without VDroop )
CPU VCore ( 1.2875v )
CPU VTT Voltage ( +275 )
CPU PLL VCore ( 1.800 )
IOH PLL VCore ( 1.350 )
DIMM Voltage ( 1.62 ) (1.65v in E-LEET, at 1.65v BIOS is reads 1.69v)
DIMM DQ Vref ( +0mV )
QPI PLL VCore ( 1.375 )
IOH VCore ( 1.375 )
IOH/ICH I/O Voltage ( 1.550 )
VTT PWM Frequency ( 250 KHZ )
CPU PWM Frequency ( 940 KHZ )
CPU Impedance ( Auto )
QPI Signal Compensation ( Auto )
ICH VCore ( 1.150 )
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Disabled )
CxE Function ( Disabled )
Execute Disable Bit ( Disabled )
Virtualization Technology ( Disabled )
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( 4.800 GT/s )
OC Recorvery ( Enabled )
PnP/PCI PCI Express
Maximum Payload Size ( 4096 )
Bios ( S61H )
CPU ( 920 D0 )
Drivers ( 191.07 )
Frequency Control
MCH Strap ( Auto )
Memory Feature
tCL Setting ( 7 )
tRCD Setting ( 8 )
tRP Setting ( 7 )
tRAS Setting ( 20 )
tRFC Setting ( 57 )
Command Rate ( 1t )
Voltage Control
IOH VCore ( 1.375 )
ICH VCore ( 1.150 )
CPU Feature
PnP/PCI PCI Express
