i7-875K: what am i REALLY running at?
AkumaX
12,648
4
just got an i7-875K (don't ask...) and am wondering how high Turbo works on these things.
i've only done 1 thing to o/c it for now, and that's change bclk from 133->150.
cpu-z reports a K 875 @ 2.93ghz (22 x 133), w/ the o/c @ 3.9ghz (26 x 150). is that right?
t-monitor shows it @ 1350 (9 x 150) when idle.
are there any other cpu clock speed / multiplier monitoring programs that i should use?
TIA :p
Rifter
751
cpu z is accurate. also with a k series why did you raise the bclock over just upping the multi? it doesnt really matter but why pay for the k series if you are going to not utalize it?
AkumaX
12,648
4
well, that kinda leads me to my next q, how does raising the multi affect the rest of the system? speedstep "should" make my base mult @ 9x, regardless of how high i raise it, right?
but if i were to say, raise mult to 28x, does that mean on regular tasks, it'll do 28x, for multi-threaded tasks like encoding, it'll Turbo to 30x @ 4 cores, and for a 2-threaded app, it'll Turbo to 32x on 2 of the cores?
Rifter
751
Yeah speedstep will still back it down at idle. And yes turbo will still crank it up. I noticed with my i7 though that disabling turbo allowed for a better overclock than using turbo boost.
DNorth
46
Im also interested to learn more about how OCing effects Turbo on these chips ( any chip infact ) :D
Rifter
751
Well with mine i could get to 3.6Ghz plus the turbo. With turbo disabled i was able to get to 4.2Ghz.
2March
135
For me it's still a bit of a mistery. I have a i7-920 C0 on a P6T-DeLuxe and it will run 3.8 with turbo and HyperThreading (180x21) but it won't do 190x20...
I believe it has something to do with the BCLK but haven't heard of people running into trouble already at 190.
So turbo can also be a benefit :)
jlfirehawk
417
I bought a Intel 980 Extreme and found Intel has a Turbo Monitor for Windows Sidebar that seems to do a good job of monitoring it in real time.
