- Jan 3, 2009
- 111
- 0
- 71
Hi guys,
I got around to putting my rig together today but being really damn tired after work I'm not sure if I didn't totally mess up with the tim and placing the HS (among other things). I think I lost contact when I was centering the HS but screwed it in anyway so I might have a bunch of air pockets in there now plus I don't know if I didn't put slightly too much TIM, IC7 is kind of a pain to use.
Anyway, I'm just looking for a figure to check against when I get a chance to boot up and test.
I'm using a Megahalems cooler, TIM is IC7 and a single 750RPM Noiseblocker 120mm fan.. the case also has a 180mm right above the HS and CPU. I don't know what to expect but I was hoping to use the good cooler and TIM to allow me to run these low speed fans and keep noise down, if temps allow then maybe even go for a small OC.
