i7 6700k Stock Fan Temperatures?
Crono
23,720
1,502
So I just found out today that I could remove the HDD Bay from my Case. I do have a DVD Drive so can't remove the top one. Next week I am going to fix the Cables on the Top left corner, that's the MoBo LED and the Power connector to the MoBo. Will hopefully be installing my new Cryorig M9i next week as well. Just wanted to share hehe. Its kinda crappy and Humble but it does its job well.
It looks good. :)
Even if it didn't, that's a nice Apache on top. I'm not hugely knowledgeable about aircraft or helicopters in particular, but I've always loved the design of the Apaches and the Comanche.
UsandThem
16,068
7,383
We were all there at one time.
I remember the first time I got a packet of thermal paste (with no instructions) , and I thought they sent the wrong thing because up to point all my CPU heatsinks came with thermal paste already installed on the bottom, and it was relatively dry. I was like "Do I put this stuff on and let it dry first because it is so runny compared to the other stuff". ;)
EpicSurvivor
1,044
48
It looks good. :)
Thanks man! yea that is an Apache. I love helicopters even though I know nothing about them, it was a gift from the family.
EpicSurvivor
1,044
48
I remember the first time I got a packet of thermal paste (with no instructions) , and I thought they sent the wrong thing because up to point all my CPU heatsinks came with thermal paste already installed on the bottom, and it was relatively dry. I was like "Do I put this stuff on and let it dry first because it is so runny compared to the other stuff. ;)
Lol I hear you!
VirtualLarry
56,570
10,205
Don't forget to put Thermal Adhesive on your RAM slots, want to keep them cool. :p
Edit: On second thought, don't do that, it might be baaaad.
Reactions: Drazick
EpicSurvivor
1,044
48
Lastly. This amount of Thermal paste will be fine for the M9i Cyrorig right? or a little more than that?
EpicSurvivor
1,044
48
UsandThem
16,068
7,383
Also I don't have One of the screws on my MoBo. I lost it when I was installing it and couldn't find it. Its this one here. You guys think Its going to affect it when I install the Cooler? (Picture below by CPU Connection)
A standoff and screw are important, and should be used to help stabilize your motherboard.
However the biggest concern is if that lost screw is lodged somewhere behind your motherboard, and could cause a short that could damage or kill your motherboard.
EpicSurvivor
1,044
48
I know, you right but will it affect or damage anything once I install the M9i Cooler? it says its 80 grams. What are your thoughts on that? I am concerned.
And no the screw/standoff didn't fall inside the case, I had lost it before that so I know it didn't fall inside or anything like that.
UsandThem
16,068
7,383
That cooler isn't heavy enough to be much of an issue. If you ever go with a larger one, like a Noctua, you'd want to get a screw in there.
VirtualLarry
56,570
10,205
Err, yeah. I was performing a CPU upgrade on a (now late) friend's S775 rig. Nice Abit IP35E mobo that I had picked up for him.
Well, I had to remove the mobo. When putting it back in, one of the screws didn't want to go into the standoff, and the standoff was missing. (Where did it go?) I ignored it, mostly because I was in a hurry to get it done. Well, it must have lodged in-between the mobo and chassis somewhere, because the board didn't power-on.
Thankfully, I had thought ahead, and had purchased an IP35 Pro board on ebay as a pro-active replacement. I had to tell my friend the bad news, that I had fried his board, and had to go home to pick up the replacement board and finish the job.
I certainly learned my lesson regarding strangely-missing mounting hardware.
Edit: The other fear is small screws falling into and through the grille on power supplies, especially if they are bottom-mounted, with the air intake grille on top.
EpicSurvivor
1,044
48
Well I got the cooler. I burnt/broke my CPU after installing it. Is this why my Computer is doing this? Did I press it to tight? I removed RAM to install the cooler but re-did the RAM 2 same issue.
Crono
23,720
1,502
I'd double check the power connections first, make sure the CPU fan is plugged in correctly, and then take off the heatsink carefully if it's still doing it and then remove the CPU.
After that, take a look at the pins on the CPU socket on the motherboard. You should be able to tell if the pins are bent or damaged right away. If you have a PC speaker it might give you the error code by beeping (or by an LED on the motherboard, if it has it).
EpicSurvivor
1,044
48
CONFIRMED! bent CPU Pin on the Motherboard. Now the question is do MoBo manufacturers tend to cover this under warranty? its a Gigabyte Motherboard.
EDIT Just found out Gigabyte does not offer any warranty on Bent CPU pins.
So I must have applied too much pressure on my CPU when installing the Cooler. Did I damage the CPU as well? the PCB doesn't look damaged.
UsandThem
16,068
7,383
Probably would be best if you uploaded pics of the socket and the bottom of the CPU so we can take a look.
Usually damaged pins or other damage stands out with a high-res photo.
EpicSurvivor
1,044
48
Problem is my phone is crap old Galaxy s4 and the Zoom and Autofocus don't work very well.
UsandThem
16,068
7,383
Gotcha.
In that case, probably the best way to tell is to Google something like "LGA1151 bent pins", and you should see some examples that look like:
http://www.overclockers.com/forums/showthread.php/776331-Bent-pins-on-LGA-1151-Need-help!
It's crazy that the pins were bent by simply putting on a new heatsink. You didn't remove the CPU for any reason while removing the old one, did you?
EpicSurvivor
1,044
48
Negative. I didn't remove the CPU when installing the cooler. I did remove the CPU to remove the MoBo. I was freaking out so I removed the MoBo after this and put it in the box to RMA. It was a panic attack.
I didn't think of putting stock cooler back on and trying that.
So dumb. Now I either RMA the MoBo assuming something is wrong with it or I take it back out and install it again.
I took out the RAM 3 times and it did the same thing from the Video. I tripled check every connection and it did the same thing again.
I swear I didn't screw the screws too tight. At least not with extreme force like when building something or putting a table together.
Could it be the CPU is damaged from pressure?
Please note. I thought the pins had to be straight but a friend told me they are set at an angle. So at first I thought they were all bent but honestly After he told me this I didn't notice any pins bent.
UsandThem
16,068
7,383
I personally wouldn't probably bother RMAing the motherboard if find bent pins, and you can't fix the pins yourself. From what I have seen over the years, once the Gigabyte tech sees bent pins, they will void your warranty and mail it back to you. You'd be out the money of mailing it back to them, but your call on if you want to give it a shot. I'd get a magnifying glass and carefully examine the bottom of the CPU and the socket (or take a high-res picture if you can borrow a camera, and look at it on your PC screen).
It's possible, but it's not a real big cooler, and you would really have cranked down on those screws. The locking bracket provides some additional support, but I have seen people damage a CPU by over-tightening a cooler before. Usually once you feel it stop, you don't keep tightening it down. Did you alternate tightening down both screws or did you tighten one side all the way down before starting the other side?
Yeah, they are not straight, and different sections go in different directions. They definitely aren't designed to take much abuse:
http://www.overclock.net/t/353601/damaged-motherboard-pins
EpicSurvivor
1,044
48
I didn't screw both sides a little at the time. I did all one side then the other. Never would occur to me to altetnate until you said it. Which would make lots of sense.
I will try getting my phone to work but it tends not to focus up close even if I tap the screen. Old Galaxy s4.
Sigh.
You think its Damaged CPU or MoBo? Would rather have damaged MoBo than damaged $350 CPU.
What would you think? 70% damaged MoBo and 30% that its Damaged CPU? Or the other way around?
Hell if its bad MoBo I can sell this one for some cash and buy a cheaper $120 mobo[/QUOTE]
