i7 4790k Noctua NH D15 temps.
xeph
4
Hello people, so i just got my nh d15 installed with two fans exhausting toward the back of my case and my p95 26.6 temps were hitting 84c after a hour run of large fft at 4.6ghz at 1.25, so is this normal, people with a 212 evo reported lower temps, and i have a few suspicions :
i have two 980's and i suspect they both block airflow and cause extra heat.
i also suspect they installed it incorrectly and caused paste smearing or bubbles forming
vcore was not overvolting whatsoever
ambient temperature is hot but i dont know specifics, all i can tell you is that it is warm.
my last concern is that maybe my chip has poor IHS contact.
according to a guide, sustained core temperature of 80c or greater is too hot, and i think there is an issue here with my temps, so please help. thanks
i7Baby
275
Case?
What CPU temps idle and gaming? CPU OCd? D15 fan speeds?
xeph
4
i7Baby
275
With the CPU at 84C the D15 should be going flat out.
R5 is a decent size case. Even with 2 x 980s the aiflow shouldn't be too bad.
guskline
5,338
476
I would probably take the heatsink off, clean your cpu and reseat using quality thermal paste.
paul878
874
I have a 2600k oc to 4.4ghz with a D14 and a 5930k oc to 4.2ghz with auto-voltage with a D15s, both cpu goes up to the mid 80's running prime95. I don't know how these reviewer get such a low temperature either. I have checked the cpu and heat-sink surface and found no flaws.
adamantine.me
152
4
36
www.adamantine.me
The thermal paste application is really crucial. If you didn't do the standard pea-sized dot and then install the cooler in one motion/attempt, then that is likely the source of your overheating. It's a pain in the ass, but clean it off well and re-apply.
paul878
874
I have tried all methods of applying the grease many time and my result are still the same. I think I just have the luck of getting very hot cpus.
adamantine.me
152
4
36
www.adamantine.me
Yeah I'm not sure, I've only had stock i5s that got as hot as 90 Celsius because the thermal paste was fried to a crisp. Reapplication took it down to 70s at load.
Paste > Cooler > air circulation inside case
