- Jul 21, 2013
- 12
- 0
- 0
Hi guys,
I just finished my new build (i7-4770k @ stock speeds), with HYPER 212 EVO in a fractal R4 case. I added an extra noctua side intake fan to the R4 also.
I have been seeing really high temps during prime95 8-threaded blend tests, wondering if I could get some help.
I used some ancient AS5 thermal paste (maybe 10 years old?), and I was seeing idle temps around low 40s in realtemp. This seemed too high, so I went out and got some antec formula 7 paste. Now the idle temps are lower, around 29-34. I spread the paste rather than doing a dollop in the middle.
however, I still get crazy high temps during p95 @ stock speeds. If I run for 10 minutes or so, it is only around 80. After 15 minutes, I saw it go up to around 100, throttling cut in and I killed the program. I had the case fans set to low at this point, so I reran p95 with them set to high. Again, after around 15 minutes, I saw temps going into 90s so I killed the test. I could deal with 80s--this computer is probably fast enough for me without needing to OC it, but 90s? Too high...
Any advice or suggestions here?
Thanks.
Thanks.
