In the States, the price difference between the FX-4300 and FX-6300 makes getting the quad a bad idea, and I'd rather have an i3 than the 4300 in general.
The FX-6300 - crazy cheap for what it is, IMO.
if you are gaming, I would consider also buying a faster VGA.
i hav a gtx550 ti and i will b gaming at 1366x768 reso....so i don thik it will be a prob
so, your main use is gaming?
anyway, if you can buy the i5... it's clearly the fastest CPU for gaming (compared to the FX)... if it's worth the price difference, specially with the 550 TI... I don't know... if you play SC2 and other CPU bound games, it might be,
hmmmm...thanx mate....i really am in favour of intel dis time around....in india intel rules...and the service and support for amd at my place is bad too....my frnd had to get his mobo replaced within few days of usage,and it took 2 months for the replacemnt to arrive..on the other hand it took only 2weeks for another frnd having intel...so yeaah...i ll be getting i5
dude the problem is i currently have just the amd athlon x2 5200+...so u can imagine the bottleneck i have(yeah yeah i know,a biggie)...and i bought the gtx 550ti a few days back...starting of october...so no gpu change..n i am gonna play at a res of 1366x768...so i really think i dont need a better gpu than i already have to play all games maxed out...isn it..
and to others..either i get amd or i5,i will have to get everything brand new...including ram...thats y i am eyeing a gud cpu...
Motherboards faults in India are serviced by service centers associated with Distributors of particular motherboard brand NOT BY AMD or INTEL !
dude i know that okay...i know who services the hardware..intel aint gonn asend a representative to repair my board!!!
and from wat i wrote i meant to say that amd hardware is not as abundantly available...and as a result service and support is slow for amd products...so thumps down to u!!!:thumbsdown:
Cool story bro, I stay in Bangalore & I don't see any such issues here.
care to provide proof of above ?
If you really don't want to change your graphics card (which I would strongly advise you to do), then by all means get the i5. Otherwise, consider getting a GTX 650 Ti + an FX-6300 and a cheap motherboard. Something along these lines:
http://www.newegg.com/Product/Produc...82E16814130839
http://www.newegg.com/Product/Produc...&Tpk=fx%206300
http://www.newegg.com/Product/Produc...82E16813138345
Selling your old card could get you around 70 bucks, and with that money this fits into your budget of ~$280. I think this is the way to go for your light gaming at that resolution (nothing will lag). At lower resolutions the difference would be particularly noticeable, at least according to this AnandTech article:
http://www.anandtech.com/show/6359/the-nvidia-geforce-gtx-650-ti-review
Otherwise, if you are not willing to change your card right away, take the i5 and be happy. It will drastically increase your performance in strategies and simulation games (but not so much in shooters). But, considering the fact your card is already a big bottleneck, I am not sure how the i5 would help up the performance a great deal.
Cheers.
Why do you actually want to upgrade? At that resolution and with that GPU you would probably be ok even with an old core2 duo dual core.
yes sir u said right....athlon x2 is a goddarn slow cpu...it takes forever to decompress rar archives copy larger files...the thing is i currently just want a processor dat would play all games maxed out(crysis 2,dirt3,etc)at my reso with my gtx 550ti..and i am on a hairline budget..u know saving money aint bad when u hav performance u cant distinguish between..and jst dat i want my system to work gud till next 2 years..after that out goes my oldie and no doubt i will buy an intel solid rig....Athlon 64 X2 is clearly slower than a Core 2 duo...
also, in low res/settings the GTX 550 Ti will not bottleneck the i5 in CPU bound games/situations.
