Edited Part
My take on this whole paranoid factor is in post #24 would take to much space up here
For the ultra paranoid guys I decided to play around within the paranoid zone I like to call it.
The chip was stable @4ghz with a vcore of 1.325 and cpu vtt of 1.18
Working on 4.1ghz and looks like it'll be vcore of 1.360 and cpu vtt of 1.21-1.22
For those whom aren't as paranoid the chip would stabalize with a cpu vtt of 1.38 @4.3ghz
I'm thinking tonight I'll try 4.4ghz again and see at what point it will stabalize at.
After a shakey start on Sunday night I got a chance to start some real testing on my chip. I made the mistake of updating my bios to the current one on Sunday night. It turns out that the current bios for my board is giving alot of us tweakers a rough time
After I downgraded bios this AM I started testing my chip out. What a diff a bios makes at least in my case anyways.
Currently I have the following still enabled in bios. C1E,speedstep,turbo mode. Currently the board is running with vdroop. Guess maybe I should try without vdroop also.
I'm sitting at 4.3ghz (205x21)at the moment with the following settings....In the images
Now the temps are starting to get kinda high for being on water.Guess I could maybe speed up my fans
The temps are from Intel Burn Test. OCCT temps are about 5-7 or so *C cooler for each core.
My main concern is the voltages. Vcore is kinda getting scary but more concerned about the other voltages as it seems like they may need some tweaking. Any room to play on them?
Most likely I'll back her down as I'd kinda like to play around with the 2 core 24x turbo as windows 7 seems to be pretty good at shifting the load from core to core to keep the chip cooler anyways.
Kinda on a tweaking break at the moment untill my daughter goes to sleep tonight. I figured I'd ask for some input from others who have had more knowledge in the area.
Thanks,
Ken
Thanks,
Ken
