- Apr 17, 2012
- 173
- 0
- 0
i'm sort of a novice when it comes to OC-ing..
as most of you guys know, i had a dell factory bs PC and i ripped everything off of it part by part and upgraded it part by part (theres a thread about it)
(i'm using a intel i5 650) (2C/4T, 1156)
so i started OC-ing and thanks to youtube (LinusTechTips) i was able to post boot at 4.7 ghz (1.4 Voltage, 1.3 VTT), but it didnt boot when i hit 5.0 in the same voltages (keep in mind i'm using a H100) do i need to increase the voltages? how much do i exactly need for a 5.0? thats the holy grail and i aint restin till i hit it.
i'm using 4x2 gb Vengeance 1600 mhz memory (8-8-8-24) and i put them in 1.528V instead of the normal 1.5 (should i increase voltage for memory unless i'm increasing the mhz?)
i'm using a MSI P55A Fuzion motherboard, should i do the trial and error method? and is there a possibility of me burnin out my cpu/motherboards? if so, what do i keep out of reach of?
