i5 3570k temps and voltage
CardioCain
Hi guys,
Just want abit of advice on 'safe' temps and voltage for the i5 3570k.
I currently run at 1.6Ghz idle, with temps of 28-33 and voltage at 1.280
Under prime95 I run at 4.4Ghz, with temps of between 58-68 and voltage at 1.288.
Just wondering is this was good/bad/ok?
Thanks
Yuriman
5,530
141
I strongly recommend against running with a fixed voltage, use "offset" instead.
Your temperatures are good but that's a rather high voltage for 4.4ghz.
CardioCain
Thanks for your reply.
I've tried getting an offset voltage and looked on numerous forums/guides to do this but can't seem to find instructions anywhere. I'm running an Asus P8Z77-V LX MB if you could possibly point me in the right direction?
And how would you reccomend getting the voltage down?
CardioCain
Your bios may not be exactly the same but check this page: http://rog.asus.com/129672012/maximus-v-motherboards/asus-z77-motherboard-uefi-bios-tuning-guide/7/
CPU voltage should be in "offset mode", and I find I typically don't need to add any voltage until I'm up to or past 4.4ghz.
Thanks again for your reply.
I downed the Ghz to 4.2, and changed to offset mode with the - sign. Running idle now i get 1.168v at 1.6ghz with temps of 30-35.
Stress testing I get 4.2 ghz, with volts at 1.368 and temps between 65-75 varying.
Voltage and temps seem high for the Ghz?
Yuriman
5,530
141
1.368v is extremely high, most consider 1.3v to be the upper save limit (at least on air cooling). Your temperatures look fine but voltage is concerning.
CardioCain
Yeah that's what I thought, is voltage down to chip, motherboard or? I think ill just reset to optimized In BIOS and start again, I have 1 guide to go off for it, do you know your settings at all?
CardioCain
Just a quick update, I reset the BIOS and started over, now got it running 1.6ghz idle with 1.180v with 30-35 temp.
Stressed its at 4.4ghz, 1.256v and 60-65 temp
Yuriman
5,530
141
That looks much better. =)
I prefer to overclock in Windows using Intel's utility, personally.
Ed1
453
18
Does Intel add any startup or services in the install ?
can it save a OC settings, profile etc .
CardioCain : If you know the manual voltage you were stable in , then find what the VID under load and use the below formula to get rough idea of offset voltage .
Vcore - VID = offset voltage
Yuriman
5,530
141
Here's a guide I wrote for setting up your bios and using the utility:
I posted this in another thread but this is a slight modification of it.
I recommend you try the Intel Extreme Tuning Utility for your first overclock. You don't need to reboot when changing multipliers/voltages, and it works a LOT better than the software included by motherboard manufacturers.
First you need to go into bios and change vcore to offset mode, but don't change the voltage (I set mine to +.005v because +0v wasn't available). In power saving features, disable C3/C6 and Package C states, but make sure you leave C1E enabled. Basically everything else can be left at default.
Once in windows, load up the Intel utility and max out the Turbo Boost Power Max and Core Current Limit, like so:
This basically turns off TDP limitations (your chip is rated at 77w TDP but you want to be able to draw more power than that when overclocked).
To overclock, drag the multiplier sliders up and hit apply. Do not play with the reference clock, only multipliers. You'll probably want to go up 1x at a time and run Prime95 or IBT to test for errors. When you reach a threshold where you're no longer stable, you can either increase the voltage, or drop your multiplier back down.
The max safe voltage for day-to-day usage is arguably about 1.3v, which on my board is about +132mv. I can get up to around 4.6ghz on my chip without going over 1.3v but your mileage may vary.
Taken from here: http://forums.anandtech.com/showthread.php?t=2269385&
Yuriman
5,530
141
The link in my post may simply be to the older version because I made the post a while back. The latest version is better to use.
Ed1
453
18
one last question, I saw you-tube vid and it looked like voltage (vcore) , needs a reboot before its enabled ?
it has a icon next to slider saying reboot is needed . this was not on options like multipliers .
Is that right ?
Edit: found some info on Intels site and it say no reboot is needed so not sure what I saw .
