- Oct 19, 2010
- 49
- 0
- 0
I've been looking at buying an aftermarket cooler to cool my cpu when I overclock it. It seems as though most people go to 4.5ghz, so I plan on ocing to that speed. What oc software do most people use to oc their cpu? This would be my first time I ever oc my cpu. Is the stock cooler sufficient for cooling it down, or should I go ahead and buy the Hyper 212+? I've read other forums where they mention the 212+ is the best value/$ so that's why I chose it. I've also looked into thermal paste and found this review site:
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-January-2012/1468/5
I understand that they used a different cpu and cpu cooler, but I figured it is still an accurate test of how thermal pastes performed. I believe the 212+ comes with the Cooler Master Thermal Compund Kit, which according to this site would make the cpu core temp 58C. I found a nice cheap paste on newegg for $3.50 called the Prolimatech PRO-PK1:
http://www.newegg.com/Product/Produc...82E16835242020
According to the thermal paste review site I would see core temps of 47C which is definitely worth $3.50 considering that's 10C cooler for such a cheap price! I don't really have a problem with the packaging of the paste, as long as it actually works. My case is the HAF 922: http://www.newegg.com/Product/Produc...82E16811119224 Any suggestions or improvements to this cooling setup, or should it be sufficient for my needs?
