davie jambo
- Feb 13, 2014
- 380
- 1
- 0
FX8350 has is faster at , you know when you are installing a game on steam and steam says "preparing files " and a wee bar starts along the box ? FX is really quick at that
So I guess 22 benchmarks in which an i5-2500k(at stock clocks) utterly TROUNCES the OC'd
FX-8350 isn't enough?
http://forums.anandtech.com/showpost.php?p=36940392&postcount=22
Intel's K processors are leagues above AMD's FX-8350. That's a given.
Please though, post your fringe benchmarks or synthetic ones, be my guest.
no because I don't care
I have got both chips though and there is hardly any difference in them despite what you may think. I use the intel one more and it is slightly better but it's like single digit frames better
Why do you love intel so much ? They are just a company that makes chips
heat output from anything after sandy has been worse.
I don't love them though I honestly could not care less about intel or amd
I get exasperated by people claiming that the fx cpus are garbage when I have both and tbh if I put both in front of you , you'd be struggling to tell them apart
Same here. I did a search in this forum to determine if a CPU upgrade is worth it.
Currently running a 2500k at 4.7Ghz on a Z77 board and just upgraded to a R9 290 (4GB). So a MB+CPU upgrade wouldn't really be worth it for the new video card?
