i5 2500K to 4690K or 4790k?
PhIlLy ChEeSe
962
@OP
I've had your board and your CPU, both of them properly cooled are good to 5MHz. You got 2 good years in it as long as you keep an eye on temps.
steve wilson
839
I have an i5 2500k @ 4.3ghz. I don't think I'll be upgrading until skylake... well that's the sensible side of me... the hobbyist side of me is itching badly.
Edit: all I really do is gaming.
BonzaiDuck
15,877
1,548
As is the hobbyist in us all.
Per AgentUnknown's remark -- What is "genie?" I never had any problems clocking to 4.5 and up to 4.7 on my HT-enabled system. It might have even more potential with HT disabled.
But all this talk of overclocking a Sandy Bridge is sort of "meh" -- yesterday stuff. I could advise, but different motherboards may be . . . different . . .
PhIlLy ChEeSe
962
Same board? What are your oc settings? Voltage? I am using of genie for oc.
I just saw I had a G45 I can't recall my settings as it has been a few years, crank up the voltage(I had water cooling)little at a time then change the multi, always watch temps. Even with good cooling I think the thin line starts around 1.5v on the CPU, water raises that a bit. Also every CPU is different some requiring more voltage then others to hit a OC.
There are many Sandybridge OCing guides
http://forums.pureoverclock.com/cpu-overclocking/11861-beginners-intro-sandybridge-overclocking.html
RussianSensation
19,458
765
I disagree. Upgrade. Both Evil Within and Lords of the Fallen showed a fat delta of 10FPS+ between Haswell and SNB. Don't be surprised if you see that gap next year with new AAA games. Plus Z68 and older platform wise is pretty meh compared to Z97.
Lords of the Fallen:
780Ti ~ GTX970 gets 72 fps min / 84 fps avg on 5960 @ 4.6Ghz
http--www.gamegpu.ru-images-stories-Test_GPU-Action-Lords_Of_The_Fallen-test-LordsOfTheFallen_1920.jpg
A 4.2Ghz 2500K will be very close to a stock i5 4670K in performance and faster than a stock 2600K. Basically, his CPU would completely max out the 970.
http--www.gamegpu.ru-images-stories-Test_GPU-Action-Lords_Of_The_Fallen-test-LordsOfTheFallen_proz.jpg
At 2560x1600, you are GPU limited with a 970.
http--www.gamegpu.ru-images-stories-Test_GPU-Action-Lords_Of_The_Fallen-test-LordsOfTheFallen_2560.jpg
Evil Within - very poorly optimized port with meh graphics
"Is it possible to run The Evil Within on PC at a locked 1080p60?
Not even an overclocked i7 and the fastest GPU on the planet can manage it."
~ Digital Foundry
Even a 980 with i7 3770 @ 4.3Ghz drops to 38-42 fps at 1080P. < This particular game is a slow title that provides no benefit whatsoever when running it at 60 fps vs. 40 fps. It's pointless to spend $ on a new CPU + Mobo for this title.
Z68 vs. Z97 - there is nothing really on Z97 that's revolutionary other than PCIe 3.0 which barely matters against x16 2.0 and M.2 which is dead or alive at the moment given the lack of M.2 SSD offerings on the desktop. Unless he is running a lot of SATA 3 HDDs in Raid, he can wait for Z107.
The 3 games really worth upgrading for from i5 2500K are Crysis 3, BF4 Multi-player and Arma 3 multiplayer. With a powerful enough GPU setup, AC Unity would benefit but a single 970 will be entirely GPU bottlenecked.
OP, I would wait for Skylake at this point. No games coming out this year will push your 2500K @ 4.2Ghz to warrant a worthwhile upgrade.
BlueWeasel
15,943
475
I was thinking of building a new PC next year to replace my Sandybridge 2700K system, but the feeling that I get from this thread is that I should wait...
Same here. I did a search in this forum to determine if a CPU upgrade is worth it.
Currently running a 2500k at 4.7Ghz on a Z77 board and just upgraded to a R9 290 (4GB). So a MB+CPU upgrade wouldn't really be worth it for the new video card?
swilli89
1,558
1,181
When deciding to upgrade I try to ask if I were to take a blind test so to speak, with a computer on the left with one cpu or gpu, and a computer on the right with a different cpu and they were running the same game. Could I pick out which was which? If it's not different enough to detect with your own eyes then why spend tangible dollars on an intangible thing?
steve wilson
839
You have a very nice OC on that CPU. I don't think you will see any increases in performance from upgrading that CPU+MOBO, except for a few certain games like BF4 multiplayer. It's totally not worth it yet. Which is good in a way really, because we can all save some money :)
Ketchup
14,553
248
DDR4 is big money right now. Might want to wait for it to get mainstream and drop in price.
I had a few reasons for my upgrade:
- The more cores with Hyperthreading do a better job of handling multiple VMs at once.
- Video editing times are improved
- My file/media server needed any upgrade and is running MUCH better with the 2500k.
I don't notice any increases in gaming. Now, my newest game is about 2 years old, so YMMV.
Denithor
6,298
23
Yes, it is, for games and most any single-threaded applications you use: http://www.anandtech.com/bench/product/288?vs=697
Stick with your 2500K.
If you are worried about your temps going forward, you might consider re-seating your CPU. AS5 is supposed to be applied in a long thin line on i5 chips, not spread out manually. The pressure of mounting the HSF provides the spreading force to obtain the desired coverage. Plus, a "pea size" wad was likely too much, may have spread off the chip onto surrounding territory - not a good thing with AS5.
http://www.arcticsilver.com/pdf/appmeth/int/vl/intel_app_method_vertical_line_v1.1.pdf
exar333
8,518
8
The only worthy upgrade from an overclocked 2500K (IMHO) would be a HW-E.
davie jambo
380
I own an i5 2500k and a FX8350 and there is not much between them in gaming when paired with the same card. I would not "upgrade" to the FX chip either mind you
tential
7,348
642
121
How about from 2500k to 8350
That would be a huge downgrade.
ha Mr Intel sales rep strikes again
No it's not
So I guess 22 benchmarks in which an i5-2500k(at stock clocks) utterly TROUNCES the OC'd
FX-8350 isn't enough?
http://forums.anandtech.com/showpost.php?p=36940392&postcount=22
Intel's K processors are leagues above AMD's FX-8350. That's a given.
Please though, post your fringe benchmarks or synthetic ones, be my guest.
tential
7,348
642
121
No it's not
Discredits a members comment.
Backtracks.
When asked to give proof:
no because I don't care
Just wow....
All in a matter of 90 minutes David Jambo manages to call a person out for being a schill, backtrack that claim, and refuse to give proof.
And with that, there goes any credibility of anything else you have to say.
davie jambo
380
I have got both chips though and there is hardly any difference in them despite what you may think. I use the intel one more and it is slightly better but it's like single digit frames better
