i5 2500k owners, is everything OK?
slag
10,473
I'm running a 2500k on a Gigabyte PH67-UD3-B3 and its smooth and fast. 4.5 ghz and very stable.
Skott
5,730
i5 2500K and the ASUS P8P67-M Pro and no issues. If you research your mobo properly and pick a good quality one there should be no problem.
nsdjoe
25
Quick question since I've yet to do any overclocking in the turbo boost era. Is that 4.5ghz you mention your full-time speed with turbo disabled? Or the max single-core turbo? Or the max four-core turbo?
TIA.
grkM3
1,407
IM running 4.8ghz air cooled on p67-pro and its been rock stable since day one.I even went threw 2 of them because the first one got the sata recall and both overclock exaclty the same.
Im even using 4 sticks of ram at 2200+mhz with decent timings.
ensign_lee
401
TIA.
That's the speed that each individual core can reach. Each core will be at 4.5 Ghz if you have it at 100% load.
rbk123
745
348
Nice. What voltage, temps, and cooler are you getting/using?
soundasleep
80
2500k with a Gigabyte GA-H67A-UD3H-B3 board. No overclocking. Major motherboard problems within a few days (boot cycling in particular). Nothing wrong with the processor as far as I can tell.
[FONT=arial, helvetica]
[/FONT]
slag
10,473
TIA.
Full time 4.5 ghz with turbo disabled.
