- Jun 2, 2012
- 6,470
- 32
- 91
I'm using the ASRock tuner that comes with the Z77 motherboards.
I changed my settings so the cpu stays at 3.3, I don't like it dropping down to 1.6.
My main question is about the vcore, i thought it is supposed to be closer to 1.2-1.3?
I guess as long as it is running great (it is) and temps are great (they are) I shouldn't worry about it too much.
1st word of advice then....Delete the worthless Axtu software as it sucks! I've tried it and it will mess around with some other apps that monitor temps, voltages, etc. Best to just remove it from system.
Locking your cpu at 3.3ghz is kinda pointless. If you need the power the cpu will ramp up quickly anyways. Mine idles at 1.6ghz but ramps up to 4.8ghz on load![]()
