- Mar 21, 2000
- 156
- 0
- 0
Hi All, As you all suggested I got the I-will 266k and Tbird 1.2 Ghz
However when I first ran them my PC was running at 900mhz.
Some of you said that it's cause of the bus being set to 100mhz by default and that I should set it to 133 to get my full 1.2ghz.
I went into BIOS and in one of the menus it said CPU clock and it was running at 100, so I changed that value to 132mhz (that's the Maximum I could get).
I touched nothing else everything else is default.
Now, ever since I did that my PC keeps freezing as soon as I restart the computer./
it starts a little finds the IDE drives then stops, or sometimes it'll go a little further and freeze. I dont know why this happens. I am running the PC along with a 128 and a 256 RAM chpi both PC133.
I have been desperatly trying to get into the BIOS to change the bus speed back to what it originally was, at least for the time being, but I cant even do that.
it rarely gets as far as the BIOS at restart, and when I do succeed and get in, the PC freezes instantly before I get the chance to reset BIOS to default.
What would you suggest I do to solve the problem?
Why is it freezing anyway?
And how can I reset the BIOS to default? Is there any manual/hardware way of doing it?
Please help
Thanks.
G>
Please help
Thanks.
G>
