This Ling Long proves that a complete tire design involves more than just a tread pattern, because the L688s V-shaped layout is essentially a copy of Yokohamas AVS Sport tire.
Consistently finishing last in all of the performance categories, the Ling Longs dry autocross performance was so far behind the other tires that we had to round its score up to zero to keep it from being negative. Geswein used the words hard and skatey to describe the Ling Longs feel. Their best showing was on the
skidpad, where an 0.88-g effort tied the Yokohamas for last.
Things got worse in the wet, where slip-and-slide behavior required a conservative effort to stay between the cones. The Ling Longs were a full five seconds off the autocross pace and needed 22 more feet1.5 3-series car-lengthsto stop from 50 mph than did the best Hankooks.
On the street loop, we were irritated by a low-speed drone, and these were the only tires to squeal under semi-aggressive cornering.
Aside from tires, the parent company, Shandong Ling Long, in Zhaoyuan, China, also specializes in cement. Is this a strategic advantage? Were not sure, but the Ling Longs showed the least wear after testingwe nicknamed them the Live Longsso there may be a connection. But even though they cost half the price of many competing tires, they scored less than half the points of even the eighth-place tire. To us, that doesnt qualify as a value, even at $57.
http://www.caranddriver.com/comparisons/nitto-invo-page-4
