Originally posted by: Jahee
And now i think i've pushed some wax down my ear hole, and now i cant hear properly out of my ear!! how do i fix this?!
Originally posted by: djheater
If that fails, go to a doctor, who will do the same thing and then reach in with a masonry drill just for laughs.
Start to tell it a story, then never finish it? How will that help? 😛Originally posted by: MmmSkyscraper
Wow, the thread quality is off the scale tonight!
Get your ear syringed, although they'll probably tell you to soften it up for a few days before you go with that stuff you buy at the chemists.
Originally posted by: JulesMaximus
Man, this thread is just begging for a "I was cleaning my ass..." parody thread. :laugh:
Must resist urge...
QFT. If you go to the pharmacy and get some earwax remover with one of those rubber bulbs, you can soften it and remove it with very warm water. You just have to blast it about 15-20 times to get most of it out.Originally posted by: swtethan
warm water helps
EDIT: with a syringe. Blast it out.
Must resist urge...
LOL, especially with the "How many times have you been banned?" thread knocking about.
warm water helps
I ended up having the same problem 2 years ago because one of my ears makes about 10 times more wax than the other. I went to the doctor and that's all they did....only they used such force with the warm water blasting it out that it caused my throat to burn. (all those nerves are connected, I guess)
Pay $8 and get the stuff....it will take care of it.
Originally posted by: FoBoT
get ear wax disolving drops from the drug store, follow the directions
also you'll want a ear wash bulb and some hydrogen peroxide and rubbing alcohol to help bust it out after the ear drops loosen it up
you may not believe how much ear wax can build up over the years if you have never seen it
it is hideous
Originally posted by: Lonyo
Yes.
Olive oil.
When I had my ears blocked up, the doctor told me olive oil was just as good as anything at the chemists. Then I went back and he sucked the loose/soft wax out with a sucky thing which they use (no more syringes, the mini vacuum type thing is apparently better).
Just put some drops of olive oil in your ear to soften the wax. It won't clear it, but it'll soften it, then you can go to the doctor and get him to do his thing.
Can't i damage my ear / ear drum by squirting water that fast into it!!
