Hi all,
Well, I put my new shuttle box together last night. Mixed impressions so far. Overall I'm happy and still have lots of tweaking to do.
-The system went together easily enough. Not much room in the case to mess around though! Shuttle did a nice job with the case design and extras they throw in the box. The heatsink
thing is crazy!
-Popped in a 2.8C, 1GB of Cosair memory, a WD 36GB 10,000RPM SATA drive w/8MB cache, Aopen CDRW (silver finish to match). I bought a 6-in-1 media card reader (3.5" size, silver to match) from newegg, and it had an internal 5-pin USB cable connector that didn't seem to match anything on the MB. A quick call to Shuttle support (NO WAIT in the middle of the afternoon!) got my answer and I hooked it up.
-Held my breath and fired it up (for some reason that's always the most nervous part of the install for me is that first poweron), and was greeted with the big fan powerup and quick powerdown. The screen came up, all looked good. Made some adjustments in the bios (had to enable the SATA controller to see the hard disk and disable the Floppy drive seek), then booted off to a XP Pro install from CDROM. The chipset heatsink fan was making a racket like it was hitting a cable or something, but a quick check showed nothing was in the way. the rest of the system was reasonably quiet. XP Pro installed very quickly without a hitch. Fastest install of XP I've been through. No problems with devices.
-After boot to the desktop, I powered down and installed the Audigy 2 card, which also went fine except the card was a tight fit.
-Another powerdown and I installed the ATI 9500P card, again, all went well. By this time I was so sick of the darn chipset fan that I just unplugged it. Nice big heatsink on the chip and I'll replace it later. It seem to be vibrating against the heatsink as it ran quiet without it hooked up to the heatsink.
Ran some initial benchmarks, the system scored very well, with disk scores being just higher that a RAID ATA/100 score, but below a 15,000rpm SCSI score. Right where I expected.
I haven't started to OC yet, but that's next!
What I like - it's small, it's fast, and it's cute. Can't wait to mod the case
What I don't like - darn chipset fan, it is a little louder than I expected
Kudos to shuttle for: nice design, great manual, fast motherboard with good OC features, nice packaging of cables and such.
Anyone know what I can do about this chipset heatsink/fan?
