I want to build a central tire inflation system. Need some help.
iamwiz82
30,772
13
What the heck is the official name of the valve on tires?? I have this design floating in my head about a CTIS system that would work well. Set beads on tires, allow for quick deflation, etc.
Jan 18, 2001
14,465
schraeder valves are used on car tires and older/ low end bicycles
presta valves are used for bicycle tire that carry a higher PSI load. (80+ psi)
iamwiz82
30,772
13
i was looking for schrader valves. A 1/4" female connector will fit on a schrader valve, correct?
iamwiz82
30,772
13
Originally posted by: notfred
How much more to a "Tire inflation system" is there besides an air compressor?
obviously you didnt see "central." Central meaning center. I want be able to deflate or inflate my tires all at once or in any combination. IE: fill a leaking tire using air from the other tires and to create a normal pressure between each. I want to be able to connect a compressor to a central valve which will fill up 1, 2, 3 or 4 or my tires are once along with gauging pressure in them. Driving 5 miles to the gas station from Grayling, Mi on 10psi was an interesting experience that i really dont want to do again.
notfred
38,241
4
It'd probably be a lot easier to just keep a spare tire in the car.
iamwiz82
30,772
13
not when all the tires are at 10. I want to use the AC compressor to inflate all the tires.
notfred
38,241
4
How do you get all your tires to 10 PSI? How often does that happen? It seems like you're going to a lot of trouble to avoid something that only happens once a year at most.
iamwiz82
30,772
13
more than once a year :) Anytime i am offroad. Its better than spending $100 on a rapid deflator and then another $200 on a compressor and stuff to re inflate them one at a time.
