i want a power supply for my system
imrank66
Dear all
i am going to buy a new pc having config as below.
INTEL CORE 2 DUO E8400 3.0Ghz (6MB CACHE - 1333Mhz FSB)
INTEL DP45SG (LGA775-SND+GIGA LAN-1333MHZ FSB) DDR3 SUPPORT-2X PCX SLOT
WESTERN DIGITAL 640GB 3.5" HDD 7200RPM 16MB Cache (WD6400AACS)
CORSAIR XMS3 DDR3 TWIN KIT 2X4096-1333 (2GBx2) XMS3 DUAL MEMORY KIT DDR3
XFX GeForce PCX GTX 260 896MB (448-BITS) DDRIII   (BLACK EDITION)
CREATIVE T-6100 INSPIRE 5.1
VIEW SONIC VX-2260WM 22" BLACK WIDESCREEN MULTIMEDIA HDMI
COOLER MASTER 600 WATTS EXTREME POWER SLI READY (RP-600-PCAR)
please tell me that is power supply sufficient for the above cofig or not ?
if not then what would be the choice.
It should be sufficient, but it isn't really a good power supply.
Others I would suggest that can be had for a very good price in the US
BFG LS550
Antech Earthwatts 500W or 650W
Seasonic S12 II 500W
PC Power and Cooling Silencer 500W
BFG LS550
+1 ^^^
I'd also recommend:
$86 - $20 MIR = $66!! Corsair 550 vx
Just remember that you will need 2 x 6 pin PCI-e power connectors for your GPU.
