I want 30"+ LCD monitor. Possible?
Continuity28
1,653
The prices would be prohibitively exorbitant. The difference between TVs and monitors are the pixel density and timings, to make a great LCD with those qualities at much higher sizes like 30+ inches would probably cost too much for anyone but Bill Gates.
BFG10K
22,709
3,003
The Dell one is about $2000 which isn't bad.
I'm really tempted to upgrade my 19" CRT with it, especially on account of that 2560x1600 resolution.
stockriderman
473
well,all plasma tv's have very good timings,that's why you don't see ghosting. I gues they'd need to improve resolution,but I doubt it's that hard. It's year 2006 after all...
xtknight
12,974
The Dell 3007WFP is 30" and uses a very high quality 8-bit S-IPS panel (same as Apple Cinema 30").
evenmore1
369
You could just get a projector, but it's just not the same...
Yeah, the Dell should be good enough
jim1976
2,704
Thinking about this upgrade myself.. I've seen this monitor from a friend, and all I can say is it is amazing..
Steelski
700
i am wondering why there are not more 1080p resolution monitors. just like the 42" monitor. its easy enough. there are tv's with that, why not monitors.
Continuity28
1,653
Because these monitors have higher resolutions than 1080p.
24" Dell is native 1920x1200 which is more than 1920x1080. 30" is natively 2560x1600 which is considerably more than 1920x1080. ;)
The point to the monitor vs tv, is to have the pixel density, so that resolution scales accordingly with dimensions - 1920x1080 doesn't look as good on 42" as it does on 24" because of the pixel density. A true 42" monitor would be prohibitively priced and also have an ENORMOUS resolution. :eek: They also need the tighter timings that TVs dont have.
Steelski
700
I know all about that, but the PC then suddenly becomes a lot more multimedia friendly. It would be nice to have a choice though, wouldent you say. maybee not 42" but lets say 28" or 32" or 38". thouse would be killer.
Crescent13
4,793
They have a 37" 1080P monitor at costco. That's about as small as 1080P monitors get.
BFG10K
22,709
3,003
No doubt. Gaming on it must be like gaming on a projector. :thumbsup:
