I use the remote desktop connection in xp, now i need a OSX alternative for my hackintosh
alfa147x
29,307
So i just built a hackintosh and want to use some thing like the Remote Desktop feature in XP but now for OS X
I will be connecting my macbook to my hackintosh
~Thanks
~~Alfa147x
kalster
7,355
leopard already has an inbuilt client , vnc://ip address from safari should do it.You need to enable screen sharing on the mac you intend to control remotely
alfa147x
29,307
this is what happened
Last login: Mon Feb 11 16:31:32 on console
twesh-deshettys-macbook:~ Twesh$ vnc://192.168.0.104
-bash: vnc://192.168.0.104: No such file or directory
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
I use LogMeIn Free on all my systems, as well as my families computers and it works great cross platform. Makes it simple to connect to multiple systems as they are all available from a central login point.
http://www.logmein.com
Tegeril
2,906
Yes, Microsoft provides a remote desktop client that works wonderfully and supports Vista. It's beta 2 right now, but there have been no notable bugs I've seen.
loup garou
35,132
Beta 2 is great, but man, the first beta was ridiculously buggy.
alfa147x
29,307
yeah i loved the beta
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
I personally use a combination of UltraVNC and Remote Desktop Connection depending on needs. UltraVNC isn't as snappy as RDC, but I don't have to log back into my desktop when I am done with it... so it is a trade off.
KeithP
5,664
202
I also use the free version of Logmein cross platform with good results.
-Keith
