Originally posted by: Sawyer
Here is a screen shot and I underlined a few things. It is like everything has a shadow at the end
http://img135.imageshack.us/img135/2420/screentz0.jpg
Originally posted by: magreen
LOL... A screenshot to capture.a monitor problem... I feel like I'm in a Douglas Hofstadter book...
Right on! And, while you are there turn off (uncheck) the lower options like shadows, etc. And, switch to a DVI cable.Originally posted by: harle
I may be wrong on this, but doesn't enabling Clear Type make text look better?
Right click on your Desktop > properties > Appearance > Effects > "Use the following method to smooth edges of screen fonts" > clear type..
Originally posted by: Fox5
Make sure cleartype is enabled.
You could always check this to see if it makes your text look better.
Originally posted by: 0roo0roo
no, 8 years ago the lcds were small enough that quite literally it wouldn't make a difference, it was true.
