I thought changing an O2 sensor shouldn't cost much
marincounty
3,227
I recently changed the O2 sensor on my 1993 Toyota truck. Fifty bucks at rockauto. Installing it was a major pain though, it is located on the top side of the exhaust.
I should have just paid my mechanic to do it. Doing it without a lift was hard.
sze5003
14,196
634
Maybe they insist on using oem? Or they really want to assure their profit.
I dunno the guy was friendly though. When I had shitty cars I would call in and the lady would know me instantly. I guess this was years ago because I bought the car in 2011 and have not had any issues since.
He did mention he tried a couple of places, took him 30 min to call back and say that it's a dealer part that I need if it is indeed block 1 sensor 3. They will do a diagnostic free of charge of course if I do get the work done there.
halik
25,696
Might as well just unplug the negative terminal cable and reset the light then lol.
Well you'll get that light back right away. I certainly would not be spending 500 bucks on something that just annoys you about cat efficiency.
sze5003
14,196
634
Yeah but I don't want that to ruin the other sensors since they may feed off each other. Or for my car to suddenly decrease in performance. Funny thing is when I had warranty at 20k miles I had this light on and went to the dealer two times and they couldn't find anything so they just reset it.
Although it was probably a different code or a misfire back then.
phucheneh
7,306
'Spacers' a.k.a. spark plug nonfoulers, will not help with his problem. Those are used to bring the rear sensor OUT of the exhaust stream to try and shake a P0420 (or just 'P042x,' as that whole range is different ways of saying 'bad catalyst').
Doing so is at best a grey area, where someone could plead ignorance. If it wasn't for the fact that I'm explaining this right now and you're reading it. Same thing for someone using 'O2 simulators.' Directly manipulating the performance of federal emissions equipment is kind of, you know, not legal. Shops obviously can't do it, and IIRC it's just as illegal for you to do it yourself. I don't think it's like some stuff- e.g. TPMS sensors can be thrown in the trash by their owner, but a shop can be fined ten grand for allowing any vehicle that came in with fully-functioning TPMS to leave without it. Yes, every tire shop that breaks a sensor and lets the car go is technically liable to have a $10,000 fine levied against them.
But with emissions stuff, I imagine it's just that individuals don't typically ever get caught. Pretty sure...still not legal.
Anyhow, all of that does not matter one bit, because tampering with the sensors can only reduce their responsiveness, which is actually the opposite of what he wants. He has a slow response code, which means the signal is not responding to changes quickly enough. I have rarely if ever seen a car set a code for downstream slow response. They just don't do it. The programming really only cares about seeing the proper voltage and a lack of switching, which, luckily, is pretty similar to a 'slow response'.
What I'm thinking that code (with the weird 'sensor 3' designation) denotes is that the downstream O2 is actually be used for more than a catalyst monitor- the PCM's programming is actually doing something with the info it gets from 'sensor 3,' even if it's only using it at a backup for the upstreams. On most cars, an upstream sensor problem simply means open loop all the time.
...I may be rambling. Cliffs: you need an O2. If you can find a Denso, NGK, or other Japanese OEM that claims fitment, it will probably be fine. Otherwise, I bet it's available for less than the quoted >$400. Dealer list is not that far over wholesale, typically. Play nice with the guy at the counter and he may even sell for less. It helps to wear a workshirt with a nametag. They'll ask if your shop has an account, and when you say no, they'll just throw it under someone random and give you better pricing. But I dunno, I may just get cheap parts because of my winning personality. Or something.
...either way, if you can't get a good price locally, look for a parts department that sells online. Most major makes have plenty of them selling at a generous amount below list. Hell, Ford runs their own site that prices the part at all the local dealers that were willing to be listed (unsurprisingly, the ones with high markup never show up).
sze5003
14,196
634
Autozone didn't give you a quote for the O2 sensors after they pulled the code?
Yea they did, they didn't know which one I would need or which type and they said anywhere from $35 to $200 bucks. I was on my lunch break so I decided to call my old mechanic for a quote at that point. Going to call a few more places tomorrow but they will probably want to run their own diagnostics on it as well.
Big pain in the but right now..right after all my medical bills too.
sze5003
14,196
634
Thanks for all the info. But when looking it up there are a lot of choices for the sensor. Is it a rear one, left, right? Assuming the code is correct and it is bank 1 sensor 3 and not anything else.
If I could get one myself I wonder if they will charge me more for labor. Doesn't matter actually about labor if the part is already expensive.
Zorba
15,183
10,739
I drove around with a bad behind the cat O2 sensor in my 99 Subaru Legacy for 6 years. Finally replaced it when I sold the car. The stupid code came back two days later :(. I always thought it was actually a wiring issue, considering it came back so quick I really think it was a wire issue. Luckily, the guy buying it didn't care that the code came back.
I never noticed any issues from the bad sensor, MPG was always way better than EPA estimate.
It really wasn't that bad to change. Borrow a socket from Autozone, soak it in PB-Blaster similar, and run the engine for long enough to heat up the exhaust pipe a little but not long enough to fully heat up the sensor.
sze5003
14,196
634
How did you pass inspection like that?
bruceb
8,874
111
It should be part of the Federal Emissions warranty. And if not, then figure out how to replace the part yourself. Sometimes, you need a special wrench to get the O2 unit out, but you should be able (in most cases) to get to it without taking a lot of the car apart to reach it. If you can't get to it from the top, sometimes it can be accessed from underneath.
sze5003
14,196
634
Not sure I'll have the time to do it. It's under the car, and then the wires go under the car through the carpet and under the seats. I'm horrible taking stuff apart. Now on my motorcycle it's easy as pie to work on.
Emissions warranty goes by engine rating and hours. Not sure what I understood from Mitsubishi's website about that.
Meghan54
11,676
5,208
I actually live in PA lol. Not sure why the guy mentioned something about Cali inspection having something to do with the sensor cost.
He mentioned that because your state is one of the ones listed in the Warranty Manual as having the Cali Emissions Control system vs. the "standard" Federal Emissions system......
From page 17 of the Mitsu warranty manual:
Vehicles equipped with a California Certified Emission Control System and registered in the states of California, Connecticut, Delaware, Maine, Maryland, Massachusetts, New Jersey, Oregon, Pennsylvania, Rhode Island, Vermont or Washington are also entitled to the California Emission Warranty.
From page 21 of same manual:
The California Air Resources Board and MMNA are pleased to explain the emission control system warranty on your Vehicle.
In California, Connecticut, Delaware, Maine, Maryland, Massachusetts, New Jersey, New York, Oregon, Pennsylvania, Rhode Island, Vermont and Washington, new motor vehicles must be designed, built and equipped to meet California's stringent anti-smog standards.
The California Emissions Warranty is more stringent and longer than the "standard" Federal warranty. You need to hit the dealer to fix the problem under the emissions warranty if you're within the mileage limits. (It's rather confusing how Mitsu puts the terms of the Cali warranty, which includes time limits of 5 years, 7 years, and/or 8 years and varying mileage for various components.)
sze5003
14,196
634
And in order to get them to honor that warranty would they know how many hours based on engine speed have passed since I bought the car? I have 64k miles on the car and based on that they said it's not under warranty. Would their diagnostics be able to clarify the usage of that component. I feel like those terms are stupid. It should be in years not hours of component life, if they are going to have that type of warranty.
sontakke
895
11
You pay them $54 which should be refunded to you. This is covered by 8/80 Federal Emission Warranty. Google it up. There is no question on it. Dealer is on the hook to fix it so that it passes emission. Find the relevant section from the federal document, print it and take it with you. He *will* relent once you show him that you know your stuff. As far dealer telling you "not covered under warranty", if you are not willing to fight for your own rights, just pay them whatever they are asking as you don't want to seem to push this.
sze5003
14,196
634
Yea I'm reading that section now on the mitsu site. Going to print it out and call for an appointment Saturday to have them do a diagnostic. My luck I'll get the run around. I'm trying to understand the warranty terms though...engine certified as variable or constant speed, max power, rated speed..can't find any of that stuff. It's definitely a 2.4L 125kw.
According to the chart, it must be greater than 19kw but less than 37 to be qualified for warranty.
It also states if your engine warranty is longer than your emission warranty period, then emissions warranty extends to the same as the engine warranty. Based off of this I'm not sure it qualifies.
http://www.mitsubushi-engine.com/REV/s/emissions
sze5003
14,196
634
Went to the dealer and showed them the paper work for the federal emissions warranty. They tell me the catylct converter and fuel injection system would be covered but O2 sensors are part of maintenance which is included in the 5 year 60k mileage package which I'm obviously over. Didn't even get work done today I've been arguing on the phone and even drove 6 miles from work with the printed paperwork for the emissions for them to tell me they will gladly do a diagnostic but the sensors aren't covered.
railer
1,552
68
Well.....I wouldn't personally spend 5 cents to replace a downstream O2 sensor. There is probably a 1 in a million chance that your cat is actually plugged, and that would be bad, I'd be willing to chance that as it is such a remote possibility.
I'd at least drive the car until inspection was due again, and depending on the law in PA you might even be fine without it. I know in NY, you are allowed to have one "pending" OBD2 code, and as the cat codes are typically the last to acquire data after a reset, you can often sneak them through inpsection that way. I drove my 2005 Grand Prix for years with some bs P042x code.
Midwayman
5,723
325
I'm not sure how they can claim that.
COVERED EMISSION PARTS
• Catalytic Converter(s)
• Electronic Spark Control
• Evaporative Emission Canister, Evaporative Emission
Liquid Separator and Controls
• Exhaust Gas Recirculation Valve and Control System
• Fuel Tank Filler Tube and Cap
• Induction Control Valve Assembly
• Multiport Fuel Injection System
• Positive Crankcase Ventilation Valve
• Timing Advance/Retard System
• Hoses, Clamps, Brackets, Pipes, Gaskets, Belts, Seals
and Connectors used in the above systems
• Vacuum, Temperature, Altitude, Speed and Time Sensitive Valves and Switches for the above systems
• Any other components necessary to assure conformity.
If failure of one of these components results in failure of
another part, both will be covered by the performance warranty
Seems O2 sensors would fall under the last bullet point as they are necessary to assure conformity.
And in California
“CALIFORNIA” EMISSION WARRANTY
24
• Accelerator Position Sensor
• Air Flow Sensor
• Camshaft Position Sensor
• *Catalytic Converter(s)
• Crankshaft Position Sensor
• Emission Solenoid Valve
• *Exhaust Manifold(s)
• *Exhaust Manifold(s) with Catalytic Converter(s)
• *Exhaust Pipe(s) between Exhaust Manifold and Catalytic Converter
• *Exhaust Pipe(s) with Catalytic Converter(s)
• Fuel Filter/Evaporative Emission Separator
• Fuel Injectors
• Fuel Level and Fuel Pressure Sensors
• Fuel Pressure Regulator
• *Fuel Pump
• *Fuel Tank
• *Fuel Tank Filler Tube
• Fuel Tank Filler Cap
• Ignition Coil(s), High Voltage Wires and Boots
• *Intake Manifold
• Knock Sensor
• *Liner A/F Sensor
• MAP Sensor
• Oil Control Valve
• Oil Filler Cap
• *Onboard Emission Diagnostic Device
• Spark Plugs
• *Throttle Body
• *Transmission Control Module
• *Valve Lift Control Motor
• *Valve Lift Control Unit
• Valve Lift Sensor
• Control Relay, Registers and Solenoids used with the
above systems
• *Engine Control Module used with the above systems
• Oxygen Sensor(s) used with the above systems
• Temperature Sensors used with the above systems
• Vacuum Hoses, Clamps, Fittings and Tubing used with
the above components and systems
• Vacuum Sensor(s) used with the above systems
