I think something is wrong with my DSL PPPoE configuration
PolymerTim
OK, so all at once I have moved to a new state (Connecticut), clean installed WinXP Pro (used to use 2000), and got a new ISP. Now I'm having some problems and have no clue what is causing them. The ISP is SBC SNET DSL using PPPoE. So my comp is directly connected to the DSL modem (no firewalls or routers) and I have a home network running opn a second NIC with ICS working just fine. I'm still waiting for full speed, but I've been told it takes up to 10 days for the modem to optimize the connection. My problem is that a few of my programs can't seem to find the internet connection. When I try to run Everquest and the game attempts to find the patcher I get an error message saying that there is not internet connection, even though IE6 works fine. And the message is almost instantaneous so I think the problem is most likely internal to my computer or at most the DSL modem. Magelo also can't connect to it's patcher. That was my only problem until recently. My distributed.net client has been happily crunching RC5-72 packets and updating just fine over the new connection. A couple days ago I updated to the most recent version of the client and now it can't find the connection either. I tried reverting back to the copy that had worked, but it still can't find the connection. There's got to be something wrong with the configuration somewhere. Maybe it has something to do with ports, I don't know. I've got a tech request into EQ in case they can help, but they're are taking a long time, and I'm ansi. I'm not currently playing on EQ, so it's no big loss, but I just would like to know that everything is working properly. Let me know if you guys have any ideas or need any more specific info.
