I think something is wrong with my case
JPodL
7
I am in the process of building a computer. It's the second computer I've ever built. The first one turned out all right, but I really don't too much know what I'm doing yet. I got it together and pushed the power button. When I did nothing started up and only 2 lights turned on. The CDRW light flickered, and a light on the motherboard turned on. Other than that, nothing happened. Any help is greatly appreciated. Thanks.
GAZZA
1,987
Start with the bascis , ensure that your components are correctly inserted into their respected slots/sockets , especially your ram if it is DDR as they seem to take more effort .
Are you getting any beep codes or led display errors ? If so you might want to check your manual for a list of those errors to determine what the problem is.
Also listing your pc's components will help others here to help you .
JPodL
7
Thanks,
I get no noise, just the two lights. My parts are:
Gigabyte GA-7VRXP w/Athlon XP 1800
PC2700 512mb ram
WD 80 GB WD800JB
Lite On 32X12X40 CDRW
Toshiba DVD (SDM1612)
Aopen GF4Ti4200 (128mg)
Teac 1.44MB Floppy
SB Audigy 5.1
This Case
GAZZA
1,987
Have you tried clearing the cmos to clear you bios of any settings ?
After quickly looking at your vid card I thought you might have difficulty running it unless you had a decent psu , but checking your case reveals a decent wattage psu , but not really sure if it is amd approved (for what it's worth).
Have you tried removing everything apart from your vid card , memory and cpu and go from there to see if your able to boot ?
JPodL
7
I hadn't even gotten that far. I took apart the other computer I built, stole it's power supply, and stuck it in my new case. That did the trick. Now I just have to go about getting a new power supply. Thanks for your help.
GAZZA
1,987
Is that case with the PSU that gave you problems new and did it come with a PSU installed ?
If so I would be inclined to RMA it .
