I have a friend who bought a used IBM Aptiva that was full of junk, so I told him I would erase, format and reload windows for him -- that is where my nightmare began. With the help of many of you (THANKS!!! 🙂 ) I have been able to get the OS loaded (Win98) and, with the help of a patch from WesternDigital, the computer now recognizes all of the hard drive. Now the last of problems (I hope) I need help with:
When the Win98 install completed, the hard drive controller in the device manager would not work right, both of the channels were displayed with the exclamation marks and as a result the CD-ROM drive does not work. It will sometimes hang on start-up and a blue-screen message will say:
<< Your multi-function device (Opti 826612A or Viper-M/N+ Dual PCI IDE Controller) has some child devices using 32-bit drivers and others using compatibility-mode drivers. This configuration is not supported, so your computer has been halted to prevent corruption. >>
Then it would place a NoIde entry in the registry. I can go into the registry and delete the NoIDE, but when I restart, I get the blue screen again and it automatically puts it back in the registry.
The chipset that the computer uses is Viper-M from Opti. Windows98 claims support for 2 or 3 Opti chipsets. Searching internet I went to Opti's web site and they say:
<< OPTi does not provide drivers for its IDE controllers, since they use the standard drivers found in Windows that are loaded automatically during Windows installation. >>
So here I am -- OPTi does not provide drivers and the ones in Windows don't work. I have searched and searched on the net, and have found many people complaining of the same issue, but haven't found any solutions. So I came here, if I can get help anywhere it will be here!!! 😀 Any Ideas???????????
