Car is a 2003 Toyota Echo. The car normally rattles a ton from various places, but a couple weeks ago I noticed a new noise. It's hard to describe but kind of a cross between a gurgling and a ping. The noise only appears under load at low RPM. It also seems to go away a bit once the car warms up. It will not make the noise if I press on the accelerator when in neutral. Oh, and no CEL.
Did some research and it seems like the noise is probably knocking. Last tank of gas I put in premium and sure enough the noise went away. After running that tank out I put regular in and the noise has come back but not quite as loud (though tank is probably 25% premium since it wasn't empty when filling).
Where do I go from here? What's the normal first step?
