Zenmervolt
Elite member
- Oct 22, 2000
- 24,512
- 21
- 81
Some dummy that called himself a mechanic said the check engine light doesn't matter (usually just for emission stuff), but even if is just a sensor, I am quite paranoid whenever I see that light. This thread is definitely a good reason for that.
The key is "usually." For example, the most recent time the check engine light came on in my car was for the barrometric pressure sensor. That's what the car uses to tell if it's at high altitudes (over ~4,000 ft.) and lean out the fuel map due to the lower air density. That I could have allowed to be on forever.
However, the prior time it was for a misfire (old spark plugs). That could have caused serious damage if I hadn't fixed it immediately.
You just don't know until you check the code. And, if you have a code for something unimportant and let the light stay on, then you'll have no way to tell if it triggers a second, more serious, code.
ZV
