Whether or not its a heat problem, I dont know. Here is what happens.
I leave my computer running for an extended period while im away (8-12 hours). When I come back the system is non responding. Now, sometimes the video won't come back on (I'll move my mouse, type something, but nothing), or the video will come on and the system will have frozen.
Now, in the case where the video doesnt come back on, I know my computer has frozen, crashed, or something. I run United Devices distrubuted computing client 24/7 and the CPU runs between 53 and 56C depending on how warm the room is (mobo is between 37 and 39C). When I come back and find it frozen up, I reboot the machine and find the CPU temp about 48C. So I know the processes have stopped running.
Here is my system:
XP2500+ Overclocked to 2.2Ghz @ 400Mhz FSB
Thermaltake SLK900u + 92mm Zalman fan
1GB Corsair ddr400
2, 7200rpm WD hard drives
430W Antec True power PSU
Now I know all of those components make a lot of heat. Frankly my case sucks. Its a little Raidmax case I bought off Newegg (the power supply already went out), and it just has one 60mm exhaust fan.
I have noticed that the computer tends to get a little warmer when I'm not on it. The CPU might be at 56, then I sit back down and start working on it and it will drop to 53 or so. I have MBProbe monitoring my temps and I have it set to log when (or if) the CPU reaches 60C. All of my logs are clear, so I'm almost certain that it hasnt reached 60C.
The system never seems to freeze sooner than about 8 hours after being left alone. I can go to bed, wake up the next morning and everything is fine. But when I leave it 10 hours or more, things just arent working whenever I come back.
Any ideas of whats going on here? Any help would be appreciated.
Here is my system:
1GB Corsair ddr400
