I think I erased the MBR! help...
Ordo1999
Banned
I was trying to ghost a drive to an emtpy drive. For some reason the empty drive over rid the source drive's MBR. So now when I try to boot with the source drive, it says Li...
There must be a way to get the data or fix the MBR...?
I've had this problem... linux right?
you need a bootable linux floppy that has lilo on it. Boot up using the floppy and run lilo once. Reboot and that should fix it.
Nope, Windows XP. I don't know why it shows Li...
Also, when I put the HD into another PC, it's showing the drive as a single fat32 partition... I really need this data back...
We had an win2k install that went awry and lost 10 gig of data off a seperate drive thast we had as a backup. Used Restorer2000 Pro. Worked like a charm - got everything back except 1 junk file. $50.00 US from www.bitmart.net.
EDIT
They have a demo version that will let you see what's possible to recover. Takes about an hour to scan a 10 gig drive. Should give you a good idea of possible recovery. Hope this helps.
I tried EasyRecovery Pro, and it only pulled some files from the C partion, none from the D partition.
hard drive before: C partition & D partition (NTFS)
Hard drive now: C partition (FAT32)
Boot using a floppy disk and run FDISK /MBR (on the drive missing the MBR). This will rewrite the master boot record without changing the partition information or anything saved on the hard drive.
I tried that. The problem is, stupid ghost created a good working single c partition. So the fdisk switch doesn't change the MBR back to the original config..
In the thread I posted, this is the software the individual used that actually worked.
Stellar Phoenix
I believe there is a free trial version that will let you know if it will work or not.
