- Sep 12, 2001
- 48,518
- 223
- 106
It's still not perfect, but it's a LOT better than it used to be..now as long as I can remember where I put everything, I should be good!
I moved in last August and never took the time to unpack everything/etc. I built a set of shelves a month or two ago and put up some pegboard, which helped - but today I threw out a bunch of stuff (mostly boxes and packing material) and organized the parts that came off (and are going into) the MR2. I also set up an 80,000 BTU heater, which works fairly well - I think it'll work better next time, since after I shut it off I felt a rather cold draft coming from one of the open windows...hmm. That window is now closed.
I stepped up on the work bench and it was a LOT warmer up there, which is to be expected...I need to put a tarp up over the rafters to help keep the heat in, and/or buy a cheap ceiling fan. Thoughts? This is a rental so I don't want to invest the time/money into properly insulating (I'm also not sure if I even could).
Waiting for spring! Well, and for me to put a turbo back in her:
Tools and stuff:
The entryway - don't mind the trash bag and backpack..they're gone now:
My solution for bigger parts that were in the way:
And for engine-ish stuff:
I need a vise and a bench grinder..other than that, it works pretty well for a small car - it would be really nice if both bays were open to each other, but for some reason they're separate (and the other bay has a dirt floor).
Tools and stuff:
