redass1876
well, i have my USB joystick plugged into the front USB on my case, and last night i got up from my desk and tripped over it. I thought it just unplugged it, but a few minutes later i started smelling part burning. I immediately pulled the power cord without even shutting down to get it off fast. I looked at the USB slot and it was all jacked up, i thought the smell was the metal on metal because the little plastic part got ripped out, so i put the plastic back in, just to keep metal off metal and then fired it back up with still the same smell.
Afterword, i opened the case, and disconnected the USB on the case from the mobo, and then tried again, but i still get the smell... I checked the system Temp, and nothing idles over 40 degrees, which has been where it has been for a long time, although i when i play games it gets to about 48 C which i thought was pretty high for a 3.0 GHZ C P4...This temp has steadily increased over the last 2 months but very slowly so i thought nothing of it as long as i monitor it.
I dont know what else could cause this smell, because the only thing that happened was i messed up that USB port, which no longer has power to it. The smell isnt as strong as before, but 12 hours later it is still there.
please advise, thanks
