I see we have ACPI Experts Here, Pls help
Fern
I just put together a new rig (NF7-S, Barton, Corsair 3200LL) OS is win98se. Had a bunch of probs with the chipset drivers for 98. I believe all is OK with exception of the below Problem Device report from sys info. This appears to have baffled those in other forums (except for Jef, a very knowledgable fellow). I was seeking the driver the report says I need.... However, I been informed I don't need a driver. Can someone please help this poor nOOB.
Thanks,
Fern/Coyote/Razor
PROBLEM DEVICES
ACPI IRQ Holder for PCI IRQ Steering
System
This Device Has a Problem: Code=9 (0x9)
Device failure: Try changing the driver for this device. If that doesn't work,
see your hardware documentation.
Registry Key: HKEY_LOCAL_MACHINE\enum\ACPI\*PNP0C0F\00000011
Alloc resources: None
Forced resources: None
Boot resources: None
Filtered resources: None
Basic resources: None
Driver: System\0004
Driver Date: 4-23-1999
System
Registry Key: HKEY_LOCAL_MACHINE\enum\ACPI\*PNP0C0F\00000012
Driver: System\0005
System
Registry Key: HKEY_LOCAL_MACHINE\enum\ACPI\*PNP0C0F\0000001A
Driver: System\0006
System
Registry Key: HKEY_LOCAL_MACHINE\enum\ACPI\*PNP0C0F\0000001B
Driver: System\0007
System
Registry Key: HKEY_LOCAL_MACHINE\enum\ACPI\*PNP0C0F\0000001C
Driver: System\0008
System
Registry Key: HKEY_LOCAL_MACHINE\enum\ACPI\*PNP0C0F\0000001D
Driver: System\0009
System
Registry Key: HKEY_LOCAL_MACHINE\enum\ACPI\*PNP0C0F\0000001E
Driver: System\0010
System
Registry Key: HKEY_LOCAL_MACHINE\enum\ACPI\*PNP0C0F\0000001F
Driver: System\0011
System
Registry Key: HKEY_LOCAL_MACHINE\enum\ACPI\*PNP0C0F\00000020
Driver: System\0012
System
Registry Key: HKEY_LOCAL_MACHINE\enum\ACPI\*PNP0C0F\00000021
Driver: System\0013
Originally posted by: valky
ACPI is used in WinXP. NF7-2 chipset is for Win2000 and WinXP use only...... 😀
Better tell nVidia to stop making their nForce2/3 UNIFIED DRIVER Win98x/ME compatible then. | :>] )
You turn off ACPI before you install the windows in the bios section............ 🙂
