- Jan 30, 2012
- 7
- 0
- 0
Hello
I ordered a HDT55TFBK6DGR Model processor ( AMD Phenom II X6 1055T 3.30GHz Socket AM3 box )
But my motherboard is N68-GS3 UCC and on the compatibility list ( http://www.asrock.com/mb/cpu.asp?Model=N68-GS3 UCC )
It says that only HDT55TWFK6DGR is compatible from X6 1055T
They also say around sites that HDT55TFBK6DGR and HDT55TWFK6DGR are mainly the same thing besides the fact that 1 uses 95 W and the other 125 W or so.
So the question is...will my mobo support the processor i just ordered or i'm screwed ? Thank you !
