- Sep 10, 2019
- 5
- 0
- 6
I was going to say that it's probably a "zero ohm llink" like the component to its right, but looking at the other components around, there seems to be a correlation between the shape of the white silkscreen outline and the component type. Therefore, it's more likely to be a capacitor like the ones above and to the right.
Depending on exactly what it's for and how conservatively the board was designed, it may still work even without that part.
I heard that if I were to run this motherboard even without that one capacitor it will cause further irreversible damage.
In the worst case, some nearby chip could be unstable without it, drawing excessive current and destroying itself. That's very unlikely though. If this was a motherboard of mine, I would have no worries powering it up as it is.I heard that if I were to run this motherboard even without that one capacitor it will cause further irreversible damage.
Such small components don't have enough room to have markings on them, so it's not possible to be sure. It will be a ceramic capacitor with a voltage rating of no more than 16V (since 12V is the highest voltage on a motherboard). There's a fair chance that it has the same value of capacitance as those other two nearby, so what I would do is remove one of those and measure it.So Mr Evil would you know what type of capacitor would it be since its not a "zero ohm link"
Although it requires decent soldering skill to repair these things, especially with the pads appearing to have lifted, it is repairable.
