fortythree
well, it has been a long time since i have been in the computer building game.. it has been a long time since i have been to this forum!!
anyways, i am itchin to build myself a new computer.. bored i guess.. i'll try and keep this post to a few general questions in regards to different choices for upgrading..
currently i have a p3v4x mobo, 512mb mosel vitelic 7ns cas 2-2-2 @ 143mhz, PIII 700e @ 933mhz, 10000 rpm 9gig scsi cheetahs, geforce 2 mmx, etc..
when i built this it was considered pretty fast.. i got laughed at by local computer guys cause i was just learning!..
anyways, my general questions are: do i go with a new high ghz P4 cpu?
OR
should I go with a dual PIII 1ghz setup? (i realize it could get pricey, but i would just do dual 1ghz rather than dual 1.4ghz if i went with the dual PIII... 1.4's are lotsa $$$)..
if I went dual PIII am i stuck with regular 168 pin sdram? do any mobo's support dual PIII's AND the newer ddr sdram?
is there a big difference in the ddr sdram compared to fast 168 pin sdram?
the main reasons i want to upgrade are: i need bigger hdd's, which meens i need to go back to win2K or XP so i can use NTFS (right now running win98 because XP seems heavy and slow on my system)..
In regards to hdd's, i was just gonna buy a quantum atlas 73.4 gig scsi so i could keep using my aha-2940u scsi card for the time being.. (8mb buffer, 10000rpm, should be fast)...
any and all help is extremely appreciated, i miss this place alot.. things change too fast!!
thanks in advance.
fortythree / Boozy43
OR
thanks in advance.
