Question I Purchased The Creative Sound BlasterX AE-5 Plus Pure Edition But I Use 2.1 Corsair SP2500 Speakers, Have I Wasted My Money?
Cassius101
157
I still use the Corsair SP2500 2.1 Speaker System which is discontinued but I consider it to be among the best 2.1 Computer Speakers ever made and I don't wanna stop using it. I have used it since 2013.
Did I waste my money? Will I still notice the benefits of having a sound card? I was thinking I won't. Using my speaker system I can't put the red and white audio inputs in the graphics card or the speakers won't work, it must be hooked into the speaker system subwoofer, unless there is some type of triple converter but I don't think there is. This means I can only use the headphone jack with the speaker system, while I will mostly be using headphones, I do like experiencing it without headphones sometimes.
The speaker system also has a remote with a headphone jack so I won't be hooking up my headphones into the soundcard so will I still notice the differences with having this sound card? I don't think the sound would be as loud on my headphones if I had them directly hooked into the sound card anyway, I could be wrong but I doubt I am.
Currently I am upgrading my computer and the new motherboard I have is the AsRock Steel Legend Wifi Z790, while the MOBO isn't so different it has Nahimic audio support and I think it looks nicer but the onboard sound isn't as good as my current mother board which is the Gigabyte AERO G Z790. The AERO G has the ALC1220-VB CODEC and the Steel Legend has the Realtek ALC897, while the ALC1220-VB is supposedly better I have seen some that say you won't notice the difference.
Dec 10, 2005
28,509
13,521
If the speakers are computer speakers, presumably, they have a standard 3.5 mm jack to hook into your audio output, either the built in on the motherboard or the sound card. And if your speakers are only red/white RCA plugs, you can always get a cheap 3.5 mm to RCA split cable.
I don't know why you'd need to hook your speakers to your graphics card.
Given the capabilities of modern integrated sound solutions on motherboards, I find it unlikely that you would notice a difference between the integrated audio output vs a dedicated sound card.
Cassius101
157
Return the sound card and buy better speakers
What is so bad about my speakers? They are among the best 2.1 speakers ever made. On HardForum someone has a similar set up as me and they say it sounds a lot better. I haven't upgraded my computer yet, still need to buy the
G.SKILL Trident Z5 Royal RGB 64GB and i9 13900k.
Cassius101
157
This exactly. Most motherboards have adequate enough sound. Either get some better powered speakers, preferably 2.0
Why is the Corsair SP2500 considered bad? I doubt you ever used them, it is a discontinued product, not many people have purchased them. They likely made Corsair a small profit at least but Corsair isn't known for making computer speakers, probably why it was discontinued since their manufacturing isn't focused on mass producing several different external speaker products. I am pretty sure it was officially sold from 2011-2018 then they ceased production.
Why should I get 2.0 speakers? I doubt many or any can peak at 232 watts like the SP2500 can.
sdifox
99,965
17,806
Best amongst mediocre is not great.
That pair will perform much better than the one you have.
sdifox
99,965
17,806
Because good 2.0 is much better than mediocre 2.1 PMPO numbers are pretty useless, but marketing loves it since it is much bigger than RMS.
It's about physics. The bigger the speaker cone, the easier it can make lower frequencies. While the Corsair is better than the typical 2.1, it is still wanting.
This one was on sale before, maybe you can wait for it to go on sale again. Ribbon tweeters are phenomenal. Of course, if you are happy withe the Corsair, keep using it but return the soundcard, it is not worth it.
<---- grew up in an electronics retailer/mid range distributor.
If you are interested you can read this. Mine you a few of the links are dead.
Motostu
576
595
Cassius, I think what I posted will allow you to connect, giving you a line level input.
Dec 10, 2005
28,509
13,521
He can just use the headphone jack on the soundcard.
Exactly. I was really confused when I initially read this thread. If it's a set of computer speakers, there should be nothing magical here. No reason to use the headphone jack on the front of the case. Just use the headphone jack on the sound card (or return the sound card and use the one on the motherboard).
Motostu
576
595
I realize that and have done the same, but for someone worried about potential distortion by overdriving a line level input I think the optical adapter would avoid that? NBD either way. Still need a 3.5mm to RCA adapter as the speaker set he has doesn't have a 3.5mm input.
Reactions: bigboxes
Cassius101
157
Why would I get those? Aren't those only 60 watts combined. The Corsair SP2500 satellites are 56 watts each and the subwoofer is 120 watts which is why it's peak is 232 watts. I rate my Corsair SP2500 8.5/10, they are not bad speakers and all reviews are very positive of them. They are probably the best 2.1 Speakers ever made, I can't find any that are as good or better.
https://lanoc.org/review/audio/5087-corsair-sp2500-21-pc-speaker-system?start=4
sdifox
99,965
17,806
sdifox
99,965
17,806
3" driver requires more power than a 5.25" driver to produce the same decibel level for a given frequency, assuming they have the same efficiency. A smaller driver has faster reaponse rate for higher frequency than a bigger driver.
WilliamM2
2,934
855
I am sure those speakers would be lucky to achieve 7 watts RMS for the speakers, maybe 10-12 for the sub? 232 watts? Not hardly.
I run home stereo speakers off a true 50 watt per channel Rotel power amp, and a 100 watt powered sub. It will blow you out of the room at half volume. Way more than needed for near field listening. But I already had the amp just sitting in the closet...
sdifox
99,965
17,806
I have 5x125w Outlaw 750 amp. Plus 2x500w sub built into my mains. And a spare Carver 505.
They have been in boxes since I moved in Nov 2011. Hopefully I'll get my projection HT setup again this year, the room is built.
Each of my main speakers is 125lbs
Cassius101
157
So you think it was false advertising, I don't think so. They sound much louder than only being 7 watts for the speakers, it is delusional if you think those satellites are only 7 watts each.
Cassius101
157
Yes I thought about using something like that before but I haven't seen this type for it.
I also thought I might be able to use this as a double input with 2 in the speaker and 2 in the sound card.
WilliamM2
2,934
855
I was only talking about my computer setup. It wasn't for bragging.
But...
My main rig runs 300 watts to each of the fronts (only 108lbs. ea) with a 2 channel amp, and a 170X5 channel amp runs the Center and surrounds (That I rarely ever use). Plus a 600 watt sub, but the amp just died on that a few months ago. :sob: One of the main reasons I hate powered speakers with plate amps. I could almost replace it for the cost of repair.
Then there is the garage setup...
WilliamM2
2,934
855
https://lanoc.org/review/audio/5087-corsair-sp2500-21-pc-speaker-system?showall=1
Yes, it's false advertising. The reviews you keep quoting never actually TEST it, they just parrot the manufacturers specs.
You're delusional if you think it really puts out 232 watts, or anywhere near that amount.
It only takes about 1 watt for 90db to 95db (depends on the speaker), add 3db every time you double the power. It only takes 10 watts to get over 100 db. Then consider that the small 3" woofers are only producing frequencies above somewhere around 120hz....
sdifox
99,965
17,806
But...
Yeah I am currently on headphones Beyerdynamics DT-770 for computer. Once my HT is back I'll move my computer down to HT. Used to play Starcraft 2 on 1080P projection and 5.1 sound xd
Plate amps should be easy to replace.
bigboxes
42,130
12,401
Those 3" speakers can't reproduce low bass and have trouble reproducing mid bass. The crossover pushes everything to that craptastic bandpass sub because your 3" speakers can't reproduce it. What you have is muddy bass and lifeless mid bass. Once you hear a pair of decent sounding 2.0 speakers, you'll wonder why you ever put up with that marketing nonsense. All you should care about are tight accurate sound.
Reactions: MangoX
