I just clean-installed win98 and the dial-up networking wouldn't recognize my modem. It automatically puts it at com port 3 with Interrupt Req as 4. On my system device manager(?), com port 1 can only have Interrupt Req as 4,5 or 7. I thought the Int. Req should be same between the modem and the port it's using. However, modem Int. Req. # wouldn't budge (either 10, or 11) and port Int. Req# would only go for one of 4, 5, or 7.
I don't know if that's the problem.
The Dial-up Networking Wizard would continue to install driver for a modem(which is already installed) and never let me "select" the modem to use.
I'm trying to install PPPOE software, but, neither the RASPPPoE or Enternet would install properly. In RASPPPoE, it says it "couldn't find any dial-up devices exposed by the PPP over Ethernet Protocal."
Please help this ignorant user desperate to use Dialpad. :frown:
thank you
yuniverse
thank you
yuniverse
