I need your help! Counter Strike and a Geforce 3
SCSIfreek
3,216
I used to have a voodoo5 card but due to the cheapness of Geforce 3 cards I purchased one. I cant seem to play Counter Strike in OpenGL nor D3D mode :( Only thing it takes is software mode. How can i fix this? using official driver 28.32 on Win2K.
--Scsi
Supradude
1,727
please specify what you mean by "can't play" ... is it crashing out of the game after loading? is it not evening loading the game? is it hanging while trying?... a bit more detail to your problem will aid in helping you solve it
Blurry
932
Seems like you probably didn't remove all the registry strings from your old Voodoo 5. I think there is a software to do such tasks.
Insidious
7,649
Definitely a driver installation issue.
1. uninstall your voodoo drivers COMPLETELY (lots of threads to help you know wtf that means)
2. don't use the auto-install for the detonator drivers (ie: don't double click the .exe file). Instead,
unzip the detonators to a directory and then install with the "have disk" funciton of Windows in device manager
3. don't install any of the other software for the video card that came with it. (some work fine, but many don't
when you use the reference (detonatorXP) drivers from Nvidia.
Hope this helps! CS should run great on a properly installed OS and GeForce3
AmdInside
1,355
I've spent countless hours on Counter-Strike with my Geforce 3. Never had a problem. Only played in OGL though so can't comment on D3D. Make sure motherboard drivers are up to date and that your display drivers for the Voodoo card have been properly removed.
Shack70
2,152
were you using the Mini-Driver when you had the voodoo??? You cant use that with the geforce :b
SCSIfreek
3,216
sorry guys, I didn't check video forum :). All other games works fine except CS.
I were able to get into the server listing but after that all i see is the loading screen.
1). I'm using the latest driver for all hardwares.
2). Did install the Video driver using the exe file.
3). Other games ran fine on this card. Mohaa, Wolf, WCIII
--Scsi
SCSIfreek
3,216
Where can i locate such a file?
Its weird that everything else ran normal or better than my voodoo5 except CS :(. I dont need 4-in-1 driver since my mobo dont have a VIA chipset on it.
I dont wanna reinstall window :( its too time consuming
--Scsi
Insidious
7,649
<all other games work fine> means you need to configure your video correctly in CS
You need to select OpenGL or Direct3D in the video modes section in the configuration screen and choose "default" drivers
If that doesn't work, re-install Half-life/CS
SCSIfreek
3,216
well guess whats up?
fresh install of Win2K w/ all updates SP2 so on
fresh install of AGP driver for Ali
fresh install of IDE drivers
fresh isntall of Nvidia 28.32 Drivers
fresh install Creative Live! drivers
Updated to the latest BIOS on Mobo
Fresh installed half-life then updates to 1009. Error Message :(
can't open GFX/shell/pattlet.lmp
your video card does not support openGL :|
Whats up with that?
Please help me out guys :) I can play wolf, MOHAA, everything else except Half-life and CS
System Setup
AMD T-Bird 1.4Ghz
ASUS A7A266 Mobo
512MB Crucial RAM
IBM 36LZX 10,00 RPM 36 Gig LVD
WD Enterprise 10,000 18Gig
PNY Geforce3 Ti200 64MB AGP w/ official driver
Creative Live!
Adaptec AHA2940U2W SCSI Controller Card
Plextor 12/4/32 CDRW SCSI
Plextor 40MAX SCSI CD-ROM
Lite-on IDE 16/40 DVD-ROM
--Scsi
krazykilroy
149
When I got rid of my voodoo card (3500), I couldn't use my nvidia cards either. Was using an ATI card forever until I just made a new system with a geforce 4 card.
I feel your pain. My geforce three was NOT responding at all, yet worked fine in every one else's comp eventually sold it for $100 after buying it for $300, and never used it.
bummer
Insidious
7,649
What happened when you tried choosing Direct3D instead of OpenGL?
(I am assuming you have downloaded and installed directX 8.1)
SCSIfreek
3,216
Yes i have DirectX 8.1 <--- got that from mircosoft updates.
Direct3D is the same. :( When I open up halflife it had that gfx error saying something about not able to open *.bmp. Its driving me crazy with this Geforce3 card. Could it be that half-life is corrupted? I mean every other games plays perfectly well and 3dmark 2001 ran flawlessly. I'm not overclocking either :(
--Scsi
Insidious
7,649
I can understand why this is driving you nutz!
Half-life is one of the less demanding games and it is the only one that won't run ?????
I don't really know what to suggest.
I think you have already tried, but.........
use hardware device manager and remove your display adapter
boot to safe mode
use regedit and look for (and remove) anything leftover from your voodoo installation
double, triple, and quadruple check your windows/system directory for any voodoo files that were not originally removed.
boot (normal)
install the detonator video drivers
boot
Uninstall Half-life
Delete (and empty recycle bin) EVERYTHING half-life
use regeit and search around for anything Sierra (be careful, only remove HL related items)
boot
turn off ALL extraneous applications (firewalls, antivirus, etc....)
ensure your System and video are not overclocked
install HL from an IDE CDROM and to an IDE hard drive (not scsi) if you can.
DON'T try to re-use your 'config.cfg' from the old (HL/voodoo) installation.
Ok, that's about as conservative as I know how to get..........
Good Luck!
SCSIfreek
3,216
I'll try it out tonite when i get home. But this is a new formatted HD so there should not be any voodoo files in there. I'll let you guys know what I find on my IDE drives. appreciate the help :)
--Scsi
