I Need You Help With A Monitor
twcracing
44
I plan on getting a 20" HD LED monitor for my new computer build. Does it matter the monitor I get? do thy all fit no matter what?
Zap
22,377
The monitor's inputs need to match your computer's outputs. The common ones are:
VGA
DVI
HDMI
DisplayPort
You only need one of those to match. Preferably, not just the VGA since that's not a digital signal.
Other than that, there's the issue of whether or not you like how the monitor looks (aesthetics) and if the picture quality is sufficient for you (panel type/quality).
mfenn
22,400
www.mfenn.com
VGA
DVI
HDMI
DisplayPort
And of course $$$$.
