I really really need a job. I'v applied all over but i still havn't been hired. I think the main reason is because i'm only 17 and i don't have any exp. Any pointers, or ideas on where to get a job?
Go to your local mall. I have yet to go into one and not see at least a couple of help wanted signs in the windows. Take anything to get your first one and do a good job then it will be smooth sailing after that. Don't give up and good luck!
Go to a temporary employment office. Call around or ask around with your friends and see if anyone can reccomend one where they place you quickly. The work involved is usually clerical and easy, but hey it's a job. Take their typing test, I assume you can type a good amount of wpm, and theyll probably place you in a Data Entry job. And then you can come back and start a post "I need a *better* Job"
