I need visual basic help please.
ahawks
11
Say you're designing an application that needs to store and item's name and it's price. What are the appropriate dim statements to create the neccessary variables? Anyone know?
randomboy
668
Its been a while, but I think you could just do
DIM variablenamehere as String??
*My edit :)
If you were to set up each variable to be strictly numeric/alphabetic, for numeric, just do
Dim variablename as single/double (whichever fits your need, if its a price, single might be sufficient, might not, think it only goes up to 32,000 something)
And for the alphabetic, just use the "as String" I think :)
Could be off though :)
Jeff
Damascus
1,434
You would probably want to create a user-defined data type (struct) to hold
the things, and then create an array of those...
Type Item
Dim name as String * fieldlength
Dim price as Currency
End Type
Dim inventory (0 to 100) As Item
inventory(0).name = "Rubber Shoes"
inventory(0).price = "9.99"
