I've had a Lian-Li PC60 for a few years, and one of the front fans is starting to give out. I've decided to replace both of the two front fans.
This being my first time replacing fans other than a cpu fan, i'm not exactly sure what to look for. Lian-Li uses ADA fans, I have no idea what the best fans are though (and i don't see ADA listed on newegg). The PC60 is able to adjust the speed of the fans, although it doesn't look like there's any special connection- is that a function of the case with variable voltage (or something?), or do i have to get special fans that can accomodate different speeds?
I'm also looking for something that's going to run quietly. I've got two harddrives, but other than keeping them cool, the rest of the case is doing pretty well heat-wise.
Any and all advice/recommendations would be appreciated.🙂 Thanks...
