I need to secure my connection ??
Macafram88
Hello all
so i just got internet and i had to supply my own router
.. and this is for my home pc
anyway i need to get a password for the connection because the wireless is unsecure and i dont want people slowin my connection down how might i go about doing this step by step
thanks any replys will help
From the weakest to the strongest, Wireless security capacity is.
No Security
Switching Off SSID (same has No Security. SSID can be easily sniffed even if it is Off)
MAC Filtering______(Band Aid if nothing else is available, MAC number can be easily Spoofed).
WEP64____(Easy, to "Break" by knowledgeable people).
WEP128___(A little Harder, but "Hackable" too).
The three above are Not considered safe.
Safe Starts here at WPA.
WPA-PSK__(Very Hard to Break).
WPA-AES__(Not functionally Breakable)
WPA2____ (Not functionally Breakable).
Note 1: WPA-AES the the current entry level rendition of WPA2.
Note 2: If you use WinXP bellow SP3 and did not updated it, you would have to download the WPA2 patch from Microsoft. http://support.microsoft.com/kb/893357
The documentation of your Wireless devices (Wireless Router, and Wireless Computer's Card) should state the type of security that is available with your Wireless hardware.
All devices MUST be set to the same security level using the same pass phrase.
Therefore the security must be set according what ever is the best possible of one of the Wireless devices.
I.e. even if most of your system might be capable to be configured to the max. with
WPA2, but one device is only capable to be configured to max . of WEP, to whole system must be configured to WEP.
If you need more good security and one device (like a Wireless card that can do WEP only) is holding better security for the whole Network, replace the device with a better one.
Setting Wireless Security - http://www.ezlan.net/Wireless_Security.html
The Core differences between WEP, WPA, and WPA2 - http://www.ezlan.net/wpa_wep.html
