- Oct 17, 2005
- 321
- 0
- 76
Hi everyone,
I have what is (hopefully) a simple problem to solve.
My condo came pre-wired with ethernet jacks. My TV stand has a gigabit ethernet switch in it with my PS3, 360, HPTC, and IP cable box all plugged in to it. Unfortunately, the wall jack that this switch is connected to (to bring it back to my central distribution panel) is behind a bookshelf, and as a result, I can't fit a standard cat 6 cable in the socket - they need to stick out from the wall an inch or so, and I have slightly less space than that.
My current solution is to use one of those terrible retractable ethernet cables because it has nice thin wires that are all laid out flat (instead of in twisted pairs). The connector is shorter and the bend radius is much smaller. This only results in a 100 mbit connection, though.
Is there an adapter I can buy to "bend" the ethernet socket 90 degrees up/down/left/right? Is there a cat 6 cable with much smaller bending radius than a standard one that I can buy somewhere?
Thanks!
Thanks!
