I need to make a Fake Newspaper for a project
alfa147x
29,307
I need to make a Fake Newspaper for a project, with some of my own articles and ads in it.
I only need it for one project so i don't want o spend the $$$ on it.
Thanks Alot...
DivideBYZero
24,117
Originally posted by: alfa147x
is there any microsoft word template?
Why? It a newspaper style. Make a few columns and stuff a couple of images in there. Et voila, Newspaper(fake).
DivideBYZero
24,117
OK, because your obviously a n00bpie I used 'Word Help'. It;s pretty technical, so I did it for you:
Text in newsletter-style columns flows from one column to the next on the same page.
Switch to print layout view (print layout view: A view of a document or other object as it will appear when you print it. For example, items such as headers, footnotes, columns, and text boxes appear in their actual positions.).
Select the text you want to format in columns:
An entire document
On the Edit menu, click Select All.
Part of the document
Select the text.
Existing sections
Click in a section (section: A portion of a document in which you set certain page formatting options. You create a new section when you want to change such properties as line numbering, number of columns, or headers and footers.) or select multiple sections.
On the Standard toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.), click Columns .
Drag to select the number of columns you want.
shuttleboi
669
If you want to make a fake newspaper that contains fake news, don't forget to label it "fair and balanced."
