i need to learn how to dance
Ns1
55,420
1,600
sure, go over tehre to the search button adn search for "dance", this has only been discussed 34095034854 times
the general consensus is:
get hammered, get on the dance floor, dance
illusion88
13,164
I guess your screwed if your under 21.
Ns1
55,420
1,600
negatron. get hammered before going into club. proceed as noted above.
Jan 31, 2002
40,819
if you.white() true
then forget.it(beloved patriot)
else
bust.a.move(dawg)
Me = cracker. Can't dance, can't sing. Ah well. :)
- M4H
SoylentGreen
4,698
If you have a hottie wanting to dance with you and you have not the guts, have a friend pour tabasco down your pants.
Deeko
30,213
12
You may suffer from, as many of us do, SWM syndrome.
SWMS, or straight white male syndrome, afflicts nearly all non-homosexual caucasion males. If you have this affliction, you simple will not be able to dance. You have have rhythem, but your body parts won't respond. There is no cure for this disease.
AznMaverick
2,776
i suffer from taht, but i'm asian...haha
NogginBoink
5,322
As much as I hate to admit this, alcohol really can help loosen you up.
Of course, so can lessons.
Chess
1,452
7
that is still the general consensus, i can dance ok and heck im not perfect but there are some guys that just cant dance and I have to laugh at them haha :)
apoppin
34,890
alienbabeltech.com
First find music you can "move to" best (rock, techno, hip-hop, country - whatever you like) . . . it really helps to scout out the dance clubs in your area to check out the music being played and the crowd that gathers there . . . .
. . . practice in front a a mirror 'till you can actually move a little like the dancers on TV (if your muscles are unpracticed, it'll help to "work-out" a few days before actually hitting the dance floor).
Then - depending on if you like what you see in the mirror - if you are serious - either get lessons or continue practicing on your own. . . . as usual, having a dance-partner helps (so find one early).
:D
